    Hi Guest,
    Yours,
    Chandoo
  2. Hi All
Adding zero as prefix Cells with Zeros
Discussion in 'VBA Macros' started by jamesexcel1970, Feb 19, 2017.
  1. jamesexcel1970
    jamesexcel1970 Member
    85
    Hello
    I get lot of data from different systems and need to clean up and real challenge comere here, we have CIN numbers which are 10 digit numbers prefix and downloaded data comes with only 5 digit need to add prefix 00000 zeros in "B" column and not sure if this possible with excel formula or vba, please suggest.
    Expected result, which i was doing manually.
    Really appreciate for your quick response.
    Cheers
  2. vletm
    vletm Well-Known Member
    2,259
    ... and You show only last five numbers from somewhere?
    As I Tip has written: Upload a Sample File to get a quicker response.
    ... if You're waiting something called 'quick response'!
    Arpanakumar and jamesexcel1970 like this.
  3. jamesexcel1970
    85
    Dear vletm.
    i work in an international organisation where data cannot be disclosed, hope you can understand and that is test screenshot from my lapy which just realised wrong thought of giving a output screenshot. Thank you.
    @ age of 50 trying my best to help my organisation with basic level of skills.
    Cheers!
    Monty likes this.
  4. Monty
    Monty Well-Known Member
    633
    May be this.
    It works wherever data with selection.
    Suggested to use in personel workbook.
    Code (vb):
    Sub Prefix()
        Dim MyRange As Range
        Dim MyCell As Range
        Set MyRange = Selection
        For Each MyCell In MyRange
        If Not IsEmpty(MyCell) Then
            MyCell.NumberFormat = "@"
            MyCell = "0000000000" & MyCell
            MyCell = Right(MyCell, 10)
      Next MyCell
  5. Deepak
    Deepak Excel Ninja
    2,689
    U can skip one line.
    Code (vb):
          MyCell = Right("0000000000" & MyCell, 10)
  6. jamesexcel1970
    85
    Sure enough will use personal workbook, been using so that i can use it in any workbook read in our forum.
  7. jamesexcel1970
    85
    How that will help! for my understanding.
  8. Monty
    633
    I can close my eyes when Deepak says...i can follow blindly, There must be a reason.
  9. Monty
    633
    Deepak
    I should really learn from u to shorten code..Hats off....It works...Thanks always.
  10. Deepak
    Deepak Excel Ninja
    2,689
    For formula =RIGHT(REPT(0,10)&B2,10)
    You can also use the same technique in vba too.
  11. jamesexcel1970
    85
    i can go with you guys..Cheers.
    Am happy for this, quickly grab a beer.
  12. Monty
    633
    Good night Guys...I hate Monday:mad:
  13. Monty
    633
    Noted.
  14. Deepak
    Deepak Excel Ninja
    2,689
    I like to using formulas in VBA with powerful evaluate fn.
    Code (vb):
    Sub Prefix2()
    Dim MyRange As Range, f As String, v As Variant, r As Range, s As String
    s = MyRange.Address
    f = "=TRANSPOSE(IF(LEN(" & s & ")>0,ADDRESS(ROW(" & s & "),1)))"
    v = Filter(Evaluate(f), False, False)
    If UBound(v) = -1 Then Exit Sub
    Set r = Range(Join(v, ","))
    r.NumberFormat = "@"
    f = "=TRANSPOSE(IF(LEN(" & s & ")>0,RIGHT(REPT(0,10)&" & s & ",10)))"
    r = v
    Set MyRange = Nothing
    Set r = Nothing
    Arpanakumar likes this.
  15. Monty
    633
    Hello
    There is a problem in this...It will make every cell into 10digits...I think it should change only numbers less then 10 should make it 10...And ignore rest.
  16. Deepak
    Deepak Excel Ninja
    2,689
    RIGHT(X,10) will always take 10 digit from the right barring string length.
  17. Monty
    633
    No luck for me...Can u include in the code you provided.
  18. Deepak
    Deepak Excel Ninja
    2,689
    My code will not touch the cells those are blank.
    Right fn!!
  19. Deepak
    Deepak Excel Ninja
    2,689
    Play like as below!!
    f = "=TRANSPOSE(IF((LEN(" & s & ")>0)*(LEN(" & s & ")<10),ADDRESS(ROW(" & s & "),1)))"
    f = "=TRANSPOSE(IF((LEN(" & s & ")>0)*(LEN(" & s & ")<10),RIGHT(REPT(0,10)&" & s & ",10)))"
    jamesexcel1970 and Monty like this.
  20. Monty
    633
    Deepak.
    Will check, Even I got the same requirement at work...But condition is only digits less then or equal to 10...Should be prefixed with zeros to make it 10 Digits....Rest should be untouched with macro.
  21. jamesexcel1970
    85
    I do not have this issue monty / Deepak as my numbers are fixed 5 digit and need to add 00000 zeros as prefix.
    Monty is looking out something different it seems.
  22. Monty
    633
    Deepak...Any luck.
    Problem is here:
    Set r = Range(Join(f, ","))
    Type mismatch.
  23. Monty
    633
    Hello
    Here is the solution.
    Code (vb):
    Sub Prefix_10()
    Dim cel As Range, rg As Range
    Dim d As Double
    Set rg = Range("A2")
    Set rg = Range(rg, rg.Worksheet.Cells(Rows.Count, rg.Column).End(xlUp))
    rg.NumberFormat = "@"
    For Each cel In rg.Cells
        If IsNumeric(cel.Value) Then
            d = Val(cel.Value)
            cel.Value = Format(d, "0000000000")
    On Error GoTo 0
  24. Monty
    633
    Another way asking user to select range and perform the action!
    Code (vb):
    Sub Prefix_10()
    Dim d As Double
    Dim UserRange As Range
    Set UserRange = Application.InputBox(Prompt:="Please Select Range", Title:="Range Select", Type:=8)
    UserRange.NumberFormat = "@"
    For Each cel In UserRange.Cells
            d = Val(cel.Value)
    On Error GoTo 0
  25. Monty
    633
    Trying to handle the error, if the user is not selecting the range then.
    Code (vb):
    Sub Prefix_10()
    Dim d As Double
    On Error GoTo Canceled
            d = Val(cel.Value)
    Canceled: MsgBox "You have not selected Range"
    On Error GoTo 0
    Thomas Kuriakose and Arpanakumar like this.
Share This Page
