I have been asked to update an existing worksheet (saved as an excel 2003 worksheet although I am working in excel 2010). The updates are very simple - I have been asked to add an additonal 5 columns. This first element of this is fine and I have managed to update the various drop downs within the 'data' sheet as these were based on tables within the spreadsheet. Unfortunately there is a linked worksheet for summarising the data (so that charts can be generated). Although I understand the logic of the formula included, I am having problems as I imagined that I could simply overwrite the existing column reference with the new one for example:
=SUM(IF((INDIRECT("Data!G2:G"&$A$1)=$B18)*(INDIRECT("Data!$T$2:$T"&$A$1)="Y")*(INDIRECT("Data!$X$2:$X"&$A$1)=H$5),1,0))
In my case:
'Data', column G relates to the gender (F/M/N)
'Data', column T relates to whether they have placed an order (Y/N)
'Data', column X relates to the number of orders, from 0 upwards
My summary table includes the following pieces of information in specified cells
$A$1 - the number of completed rows based on a CountA formula
$B18 - in this case is looking for all the Females (F)
H$5 - in this case is looking for where the number of orders = 3
The general principle of the formula is therefore saying if the value in column G (between 2 and the final completed row) is 'F', then multiply with the value in column X if this equals '3' and if the value in column T is 'Y'.
So following this logic, if I've added 5 columns to the left of the originals on the 'Data' sheet, then the column references on my summary sheet should also shift over 5 places giving:
=SUM(IF((INDIRECT("Data!L2:L"&$A$1)=$B18)*(INDIRECT("Data!$Y$2:$Y"&$A$1)="Y")*(INDIRECT("Data!$AC$2:$AC"&$A$1)=H$5),1,0))
I have literally overwritten the original values in the formula, but now it doesn't seem to work ... and yes I have added dummy data into the 'Data' spreadsheet to that it should have values.
Is there something really obvious that I am missing? I haven't previously used the indirect function
Thank you in advance for any advice you are able to offer.
Helen
In my case:
Helen
