AUTO PROTECT CELLS AFTER ENTERING DATA ONCE SAVED
SARJIL VHORA
I want to protect few cells such away that users can not edit data in few cells once file saved. i have hereby attached my excel sheet, i want to apply above protection in yellow highlighted raw.
please help me.. is it possible ??
  • INTERNAL CALL BOOKING SHEET.xlsm
You have highlighted two columns
1) Do you wan to protect whole column or only the cells which are not blank
2) This can be done only through macro. Would it be ok?
Try the below code in workbook module
Private Sub Workbook_BeforeSave(ByVal SaveAsUI As Boolean, Cancel As Boolean)
Sheet1.Unprotect Password:="password"
Lr = Rows.Count
Range("G3:G" & Lr).Locked = True
Range("K3:K" & Lr).Locked = True
Sheet1.Protect Password:="password"
Go to VBA screen and left side of the screen you can see 'Workbook'
Double click on it and on the right side paste the above code
The whole sheet is password protected
You need to unlock the cells which ever you need to be open even after sheet is protected with password
To do this select all the required cells to be unlocked, righclik and go to format,
In the format pop-up goto Protection Tab, Under protection tab uncheck the option 'Locked'
still my problem is not solved... what i want ???
- if user enters data in yellow highlighted cells and saves files then he can not allowed to re-enter data in old cells but he can enter data in new cells.
Find the below code
Lr = Rows.Count
Range("G3:G" & Lr).Select
Selection.SpecialCells(xlCellTypeConstants, 23).Select
Selection.Locked = True
Selection.SpecialCells(xlCellTypeBlanks).Select
Selection.Locked = False
Range("K3:K" & Lr).Select
Try below code
on error exit sub
Lr = Rows.Count
This will work
On Error Goto Err
Lr = Rows.Count
Err:
Exit Sub
Error during saving is solved but not fulfill prime requirement.. still user can edit previous data in yellow highlighted cells
one problem I am facing while using this sheet is user can not use option such as autofilter etc.....
is it provision to enable these ?? i have tried to enable by marking tick on protect sheet tab but it works untill i save sheets. afterwards user can not use..
Use the below code
On Error Goto Err
Lr = Rows.Count
Sheet1.Protect Password:="password", AllowFiltering:=True
Err:
Exit Sub
