    Hi Guest,
    Yours,
    Chandoo
  2. Hi All
Auto serial number
Discussion in 'VBA Macros' started by Rajendar, Dec 22, 2016.
  1. Rajendar
    Rajendar Member
    36
    I need any one help to create auto serial number as per the below conditions sheet is attached.
    Column I5:I12000 – I Need to auto generated the serial numbers in “I5”
    If there is item code, Job number, issue date if it is available based on that I need to apply the formulas,
    If the job number and date is same then next serial number has to be generate automatically.
    The Logic is
    First condition: If “O” column having the item code, generate the serial number in "I5" starting number is like MIVS-0001 ( MIVS-) Is common for all. Like MIVS-0001,
    Second condition: if there is no item code in "O"not to generate any serial numbers
    Third condition: column number “J & M” “ Issue date & Job number ” is same within the date then generate the serial number same like MIVS-0001, If the date or Job number is different Generate the serial number as next MIVS-0002.
    I Request you to please create formula or VBA without any errors with the conditions like N/A should be blank.
  2. bosco_yip
    bosco_yip Well-Known Member
    1,043
    Try,
    In I5, enter formula :
    =IF(O5="","",IF(COUNTIFS(J$5:J5,J$5:J5,M$5:M5,M$5:M5)=1,MAX(I$4:I4)+1,LOOKUP(9^9,I$4:I4/(J$4:J4=J5)/(M$4:M4=M5))))
    and,
    in I5 >> Custom Cells Format >>
    type box enter : "MIVS-"0000 >> OK
    All copy down
    Bosco
  3. Rajendar
    Rajendar Member
    36
    Dear Bosco,
    :) Great its working fine.
    Thanks for your help.
    The same can we put it in VBA ?. I Request you to please try in VBA. the reason why i am asking in VBA. I Have huge data to be enter almost i use this up to 20000 cells.
    Request you to Please help in VBA
  4. bosco_yip
    1,043
    I am not familiar to VBA, please transfer your question to the VBA/Marco of this Forum.
    Bosco
    ▬▬▬▬▬▬▬▬▬ Mod edit : thread moved to VBA forum !
  5. rahulshewale1
    rahulshewale1 Member
    82
    hii bosco sir,
    can you please explain me lookup formula ,why you sir use 9^9.
    Rahul shewale
    Thomas Kuriakose likes this.
  6. bosco_yip
    1,043
    This is a 2 criteria Lookup formula, which is designed to return the last match value.
    LOOKUP(9^9,I$4:I4/(J$4:J4=J5)/(M$4:M4=M5)) is same as
    LOOKUP(2,1/((J$4:J4=J5)*(M$4:M4=M5)),I$4:I4)
    9^9 is equal to 387,420,489 and is the BigNum of the formula.
    Try Google to search for BigNum in Excel formula, there will have a lot of examples found.
    Bosco
  7. Chihiro
    Chihiro Well-Known Member
    3,225
    For VBA try below code.
    Code (vb):
    Sub AssignMivNo()
    Dim dict As Object
    Dim i As Long
    Dim mivN As Integer: mivN = 0
    Dim resArray
    Set dict = CreateObject("Scripting.Dictionary")
    myArray = Range("J5:O" & Cells(Rows.Count, 1).End(xlUp).Row)
    ReDim resArray(UBound(myArray, 1), 1)
    For i = 1 To UBound(myArray, 1)
        If myArray(i, 1) <> "" And myArray(i, 4) <> "" And myArray(i, 6) <> "" Then
            If dict.exists(myArray(i, 1) & myArray(i, 4)) Then
                resArray(i - 1, 0) = "MIVS-" & Format(dict.Item(myArray(i, 1) & myArray(i, 4)), "0000")
                mivN = mivN + 1
                dict.Add Key:=myArray(i, 1) & myArray(i, 4), Item:=mivN
                resArray(i - 1, 0) = "MIVS-" & Format(mivN, "0000")
            resArray(i - 1, 0) = ""
    Range("I5").Resize(UBound(resArray, 1)) = resArray
    NOTES:
    1. This assumed Column A will have value present whenever there's any data in range J:O. Adjust as needed.
    2. This will actually input text string "MIVS-####" instead of just the number with custom formatting.
  8. Rajendar
    Rajendar Member
    36
    Dear Chihiro,
    Yes its working fine. thanks for your help.
    but there should be some alert is better i think. when there is no job number ref column cell "M" if i put blank. alert is msg box is " Please enter Job number " I tried with validation alert but when copy the code from other excel sheet that function is not working. is it possible to put it in vba is great for me.
    when i enter or paste the part number in "O" cells with out job number msg box is required.
    Please help me
  9. Chihiro
    3,225
    Something like below in worksheet module.
    Code (vb):
    If Target.Count > 1 Then Exit Sub
    If Not Intersect(Target, Range("O5:O65536")) Is Nothing Then
        If Target.Value <> "" And Target.Offset(, -2).Value = "" Then
            MsgBox "Missing Job Number!", vbCritical
            Target.Offset(, -2).Select
    See attached.
  10. Rajendar
    Rajendar Member
    36
    Chihiro,
    i am getting msg box when i type the part number with out entering the job number
    but when i copy and paste the part number that time i am not getting message box
  11. Chihiro
    3,225
    Are you copying more than 1 cell at a time? If so the code is meant to check when Target <=1.
    I'd not recommend doing worksheet change event for more than 1 cell at a time, unless you are absolutely sure of how users are editing range.
Share This Page
