Thank you Narayan. My manager has solved it.Hi ,
Before a formula can be suggested , can you indicate what should be the result of the formula , given the data you have provided ?
If you calculate the efficiency manually , what are you supposed to get ?
send the file!Dear Mahentesh, Total effiiency is 46.91%.
This is for you.send the file!
