    Hi Guest,
    Yours,
    Chandoo
  2. Hi All
Cannot see why code doesn't work - please help
Discussion in 'VBA Macros' started by cricketnz, Sep 10, 2013.
  1. cricketnz
    cricketnz New Member
    17
    Can anybody tell me why below code does NOT put the formula or its result in the selected cells? I can not see what I'm missing here, but I'm certainly are missing something.
    What I want to do is based on the presence of a search string in a selected range of cells (all in the same column) add the word "STOCK") in a column offset (0,4) to the right on the same rows, and if not to leave the cell blank
    Code (vb):
    Sub SelUserRange()
    Dim UserRange As Range
    Dim TopCell As Range
    Dim Bb, StrSrch, StrRepl As String
    StrSrch = "NON INVENTORY:"
    StrRepl = "STOCK"
    Bb = ""
    On Error GoTo Canceled
    Set UserRange = Application.InputBox(Prompt:="Please Select Range of Items that need to be converted", Title:="Range Select", Type:=8)
    UserRange.Offset(0, 4).Formula = "=IF(ISNUMBER(FIND(" & StrSrch & "," & UserRange(1, 1).Address(False, False).Value & ")}," & StrRepl & "," & Bb & ")"
    Canceled:
    If I put =IF(ISNUMBER(FIND("NON INVENTORY",B441)),"STOCK"," ") in any of the offset cells it works fine
    The code also works with UserRange.Offset(0,4).Formula = "=" & UserRange(1, 1).Address(False, False
    Your feedback will be greatly appreciated.
  2. Smallman
    Smallman Excel Ninja
    1,217
    Hi CricketKiwi
    Go with the following instead. If you can't get it rolling I will upload a file which works nicely.
    Code (vb):
    Sub testo()
    Range("A1", Range("A65536").End(xlUp)).AutoFilter 1, "Non" & "*"
    Range("A2", Range("A65536").End(xlUp)).SpecialCells(12).Offset(, 4).Value = "Stock"
    Range("A1").AutoFilter
    Take care
    Smallman
  3. roe3p
    roe3p New Member
    5
    The problem is that the output formula is missing all its quotes - so your final formula is reading:
    =IF(ISNUMBER(FIND(NON INVENTORY,B441)),STOCK, )
    rather than:
    You just need to add double-double-quotes into your code as follows:
    Code (vb):
    UserRange.Offset(0, 4).Formula = "=IF(ISNUMBER(FIND(""" & StrSrch & """,""" & UserRange(1, 1).Address(False, False).Value & """)},""" & StrRepl & ""","""")"
    (I've also removed the Bb variable as it's just read as an empty string rather than a double quote)
  4. cricketnz
    17
    Hi Roe3p
    Your comments made a lot of sense, so I was quick to try it out. Unfortunately, it is still not doing anything.
    If you'd like I'm happy to upload a file
  5. cricketnz
    17
    Hi Smallman,
    Many thanks for your reply, however I need more control hence the idea of selecting small ranges of the spreadsheet.
    Cricketnz
  6. roe3p
    roe3p New Member
    5
    Hi Cricketnz,
    My bad, didn't test it - this should work though:
    Code (vb):
    UserRange.Offset(0, 4).Formula = "=IF(ISNUMBER(FIND(""" & StrSrch & """," & UserRange.Cells(1, 1).Address(False, False) & ")),""" & StrRepl & ""","""")"
    I changed a curly bracket to a normal one, removed the .Value from the end of .Address and removed the double quotes from around it as well. Seems to work fine now.
    Hope this helps!
    roe3p
  7. cricketnz
    17
    Marvelous! Yes, it did! How one wrong bracket can make a difference ...Much appreciated indeed!
    Cricketnz
  8. Smallman
    1,217
    Hi CricketKiwi
    Control in VB is gained by knowing your starting point (or trapping it) and designing code around that point. Once you trap the start you can trap the last instance in the column you are working with. Selection in the world of vba is not something you should get into just because the Recorder selects objects.
    There is always a better way.
    Smallman
  9. roe3p
    roe3p New Member
    5
    Hi Smallman,
    I agree in general, but it can often be handy to have subs that only work on a targeted range (especially when working with sheets manually populated by someone else!)
    There may well be a better way to achieve what's needed in this case, but what Cricketnz has so far seems like a neat enough way to avoid blindly using 'Selection.', so I've answered the OP to help understand the issues that arise when populating cell formulas from vba.
    Cheers,
    roe3p
  10. Smallman
    1,217
    Roe3p
    I was neither addressing you, your answer or having a go. Here is how I look at every problem bar none. I will not look at the Op's code for anything but guidance for what the process is trying to achieve. Then I will completely re write the whole thing. I believe I can achieve an efficient outcome and convey a bit of learning in the process. And that is the most important thing to take away. If you do it the way that has been suggested in most cases you are marching down the path of a sub optimal solution. That is a journey I never travel.
    I still think this solution well thought through can completely avoid selection in any form. There is no file so no way to tell. CricketKiwi has two completely different solutions - in this case he will most likely not choose my solution - but hundreds of people will eventually stop by this thread and my method will be of use to some I am sure.
    Smallman
  11. roe3p
    roe3p New Member
    5
    Excellent - then let's agree to agree! :)
    Your solution is certainly more elegant, but I'd suggest one amendment:
    Code (VB):
    Range("A1", Cells(Rows.count, 1).End(xlUp))
    to define the range, rather than "A65536" - just in case the user is using Excel 2007+ and has more then 65536 rows of data. (without intending to pick nits ;))
    Cheers,
    roe3p
    p.s. - I'm new to this forum and I can't seem to select VB as my code type so it always comes out as Code (text). Can you tell me how I can output Code (vb) like you guys? Do I select PHP rather than General Code? Thanks!
    Edit: by Hui
    Marc L likes this.
  12. NARAYANK991
    NARAYANK991 Excel Ninja
    14,314
    When you click on the Code button , and insert your code , the software inserts the two tags "[" CODE "]" and "[" /CODE "]" , with your code in between them.
    Modify the initial tag to "[" CODE=VB "]". That is all there is to it.
    The only problem with this seems to be that the indenting changes , since the font is not a fixed font but a proportional font. Of course , if you change to a fixed font like Courier New , then it inserts a tag on every line , which makes it very difficult to read.
    Note that I have put the square brackets within quotes , since otherwise the software interprets the code tags literally.
  13. roe3p
    roe3p New Member
    5
    Code (VB):
    Dim test as String
    That's great, thanks for your help!
    Cheers,
    roe3p
  14. Smallman
    1,217
    Yeah I get pulled up on the 65536 thing a bit. My view is that 99% of the time I will be ok and when writing code for others and myself (few and far between) it is 100% as I don't think while XL has 1m plus rows you should use XL for a data repository that large. I use Access when the data set gets any bigger than 30k rows.
    Take care
    Smallman
  15. cricketnz
    17
    Hi Smallman
    I must admit your code is actually very smart, and I am warming up to it. excel-data.jpg
    May I ask your advice for an other challenge?
    please note attached data snippet
    How would I go about using the auto filter solution to put in the offset the value of column F when the condition of the autofilter is not satisfied?
  16. Smallman
    1,217
    Hi CricketKiwi
    I am not sure I understand your question. What column do you want to filter on and what is the criteria? What value do you want to put in a column when this condition is not met?
    I am about to fly abroad and this is probably a thread I will not be able to follow through on. I am sorry about that. There are however many smart members who will be able to further assist with your problem.
    Take care
    Smallman
  17. cricketnz
    17
    Hi
    The condition is as before and the column being filtered for the condition is column B. If the condition is met we put the word "Stock" in column G.
    If the condition is not met, I would like to copy the value of column F (as offset) in to column G
    I was wondering if we could use another auto filter for the case the first condition is not met by stating a condition that is the reverse, I.e. condition2 <> condition1
    Cheers,
    Cricketnz
Share This Page
