Cant Connect to Data source via Power Query
Dokat
I am using power query via external connection to load data. However I am receiving unable to connect error message. Please see below error message. Did anyone come across same issue and have a solve for it? Thank you
There are 2 common reasons that I know of.
  1. Faulty add-in enabled for Office applications
    • Check your add-in and turn off all but PowerQuery and see what happens.
    • Uninstall and re-install PowerQuery add-in (if using Excel 2013 or 2010)
  2. Issue with Connector/Provider
    • Download the engine and install
    • If using 64 bit windows and 64 bit office above may not work. Use THIS instead.
If one of the above does not resolve issue...
Check your machine's event log immediately after that error is generated and find log pertaining to that error. Dump to text. And ask at Microsoft support for help with that info.
