Chart required, dont know the chart type, visualization provided. Please help. TIA.
pm1978
Please help with graph. Requirement is in attached word file.
  • New Microsoft Word Document.docx
You'd use stacked bar chart with 1st series (From), with no fill/transparent.
However, you'd need helper column.
See attached.
  • Sample_DateChart.xlsb
Hi, Thanks a ton. I was trying to do the same thing but couldn't select the data as required in the chart. Please provide steps of data selection for my understanding. Thanks again.
You use Ctrl to select non-contiguous ranges.
You can also edit series formula.
=SERIES(Sheet1!$C$1,Sheet1!$A$2:$A$6,Sheet1!$D$2:$D$6,2)
Another method is to create 2 separate chart then paste one into the other.
