Check next class after "linkcell" class when scraping data
YasserKhalil
Hello everyone
I am trying to learn about scraping data and I did half of my target .. There is a list of functions and its description
Depending on class name "linkcell" I could grab functions list properly
but as for description I am confused because the class name related sometimes is "definecell" and the last one in each table "functab" is "definecelllast"
Here's the code
Sub Test()
    Dim element        As IHTMLElement
    Dim elements        As IHTMLElementCollection
    Dim ie              As InternetExplorer
    Dim html            As HTMLDocument
    Dim counter        As Long
    Dim erow            As Long
    Set ie = New InternetExplorer
    ie.Visible = True
    ie.navigate "http://www.excelfunctions.net/vba-functions.html"
    Do While ie.readyState <> READYSTATE_COMPLETE
        Application.StatusBar = "Loading Web page …"
        DoEvents
    Loop
  Set html = ie.document
    Set elements = html.getElementsByClassName("linkcell")
    counter = 0
    For Each element In elements
            erow = Sheet1.Cells(Rows.Count, 1).End(xlUp).Offset(1, 0).Row
            Cells(erow, 1) = html.getElementsByClassName("linkcell")(counter).innerText
            'Need help at this point
            'Cells(erow, 2) = html.getElementsByTagName("href")(counter).innerText
            counter = counter + 1
    Next element
    Application.StatusBar = ""
    ie.Quit
    MsgBox "Done...", 64
Thanks advanced for help
Hi !
It may be better to loop Table objects in order to read their elements …
Working with class names could be a mess as it can fail on some computers.
Thanks a lot Mr. Marc
I missed your replies since a while
In fact I am novice at scarping .. Can you give me a model code of how to loop through the table objects>> ?
Another point I think there are many tables so I would first loop through each table ... How can I do that?
As you can see in many threads of this forum there is no model code
'cause each scrapping is specific to the source webpage …
Loop on getElementsByTagName("TABLE") and foresee a table object structure (within VBE Locals window) as all is here :
observe & respect object model …
You will see in the table model some Rows objects
and within Rows some Cells objects.
Try this :
Sub Test()
    Dim counter        As Long
    Dim erow            As Long
    ie.Visible = True
        DoEvents
    Loop
    counter = 0
        With element
            Cells(erow, 1) = .innerText
            Cells(erow, 2) = .NextSibling.innerText
    Next element
    ie.Quit
    Sheet1.Columns(1).Resize(, 2).AutoFit
You're awesome and wonderful ..
The clue was in that magic part (NextSibling.innerText) ..
Thanks a lot for great help
Can you help me with looping through exisiting tables as I need to learn that too?
Best Regards
First demonstration :​
Sub DemoIE1()
    Dim oTable As HTMLTable, oRow As HTMLTableRow, C%, R&
    Application.StatusBar = "      Downloading …"
    Sheet1.UsedRange.Clear
With New InternetExplorer
        .Navigate "http://www.excelfunctions.net/vba-functions.html"
'       .Visible = True
   While .Busy Or .ReadyState < 4:  DoEvents:  Wend
    For Each oTable In .Document.getElementsByClassName("functab")
        For Each oRow In oTable.Rows
                    R = R + 1
            With oRow.Cells
                For C = 1 To .Length
                    Sheet1.Cells(R, C).Value = .Item(C - 1).innerText
                If .Length = 1 Then
                    Sheet1.Cells(R, 1).Font.Bold = True
                    Sheet1.Cells(R, 1).IndentLevel = 3
                    Sheet1.Hyperlinks.Add Sheet1.Cells(R, 1), .Item(0).Children(0).href
        .Quit
    Sheet1.UsedRange.Columns.AutoFit
    MsgBox "Done …", vbInformation, "    Demo IE #1"
An easy IE way no needing to add any reference (late binding) :​
Sub DemoIE2()
        Dim oDoc As Object, oTable As Object, R&
        Set oDoc = CreateObject("htmlfile")
        R = 1
With CreateObject("InternetExplorer.Application")
'       .Visible = True
        If oDoc.frames.clipboardData.setData("Text", oTable.outerHTML) Then
            Sheet1.Paste Sheet1.Cells(R, 1)
            R = R + oTable.Rows.Length
        .Quit
            oDoc.frames.clipboardData.clearData "Text"
        Set oDoc = Nothing
        MsgBox "Done …", vbInformation, "    Demo IE #2"
That's great and awesome Mr MarcL
Thank you very very much for these magic solutions ..
I will study these codes further to learn from them so please let me ask for anything that is unclear for me
Best Regards
I tried to get this part but couldn't get it ..
And as for Demo2
Item(0) : first item
Children(0) : first child
href : link property …
… as you can see in VBE Locals window …
And as for Demo2
Copy table data to the clipboard, see IE documentation on MSDN …
Last but not least, the faster request way (no reference to add) :​
Sub DemoReq()
    Dim oTable As Object, R&, T$
With CreateObject("WinHttp.WinHttpRequest.5.1")
    .Open "GET", "http://www.excelfunctions.net/vba-functions.html", False
    .setRequestHeader "DNT", "1"
    .send
     If Err.Number Then Beep: Exit Sub
     On Error GoTo 0
 If .Status = 200 Then T = .responseText Else Beep: Exit Sub
     R = 1
With CreateObject("htmlfile")
        .body.innerHTML = T
    For Each oTable In .getElementsByTagName("TABLE")
'        If oTable.className = "functab" Then
             If .frames.clipboardData.setData("Text", oTable.outerHTML) Then
'        End If
    MsgBox "Done …", vbInformation, " Demo Request"
You're a legend Mr. Marc
That's really awesome and fascinating demos
What is this line
What "DNT" is it a header? Where did you get it? (By inspecting elements ..?!) and what 1 ?
Another way to get the required data from that specific webpage with adding nothing to the reference library:
Sub Tab_Data()
    Dim hdoc as Object, tbl As Object, tRow As Object, tCel As Object
    With CreateObject("MSxml2.xmlhttp")
        .send
        Set hdoc = CreateObject("htmlfile")
        hdoc.body.innerHTML = .responseText
    For Each tbl In hdoc.getElementsByTagName("table")
        For Each tRow In tbl.getElementsByTagName("tr")
            For Each tCel In tRow.getElementsByTagName("td")
                y = y + 1
                Cells(x, y) = tCel.innerText
            Next tCel
            y = 0
            x = x + 1
        Next tRow
    Next tbl
Finally, if you wanna stick to the class then this one works fine as well:
Sub Vba_tabledata()
    Dim http As New XMLHTTP60, html As New HTMLDocument
    Dim htable As Object, data As Object
    With http
        .send
        html.body.innerHTML = .responseText
    Set htable = html.getElementsByClassName("linkcell")
    For Each data In htable
        x = x + 1
        Cells(x, 1) = data.innerText
        Cells(x, 2) = data.NextSibling.innerText
    Next data
Btw, add the following reference to the library:
Microsoft XML and Microsoft HTML object Library
What is this line
DNT means Do Not Track and "1" is like switching the light on …
I got it by inspecting requests under Mozilla Firefox …
This header is not mandatory, at the convenience of the coder.
From RFC blank book
As you can see, there is no model to scrap data,
as it depends on the webpage object model
and the coder feeling how to reach them …
Thanks to Shahin and its last code, getElementsByClassName
fails on my side in late binding on "functab" but in early binding
- with reference Microsoft HTML Object Library added -
no more issue pointing this functab class :​
Sub DemoReqRevA()
    Dim oTable As HTMLTable, R&, T$
    .send
     On Error GoTo 0
     R = 1
With New HTMLDocument
        .body.innerHTML = T
    For Each oTable In .getElementsByClassName("functab")
Shahin - again - do not forget to free object variables …
@Marc L,
Whatever thread it is, I find it very thrilling to get in contact with you. Something I would like to ask. The other day you taught me how to write code without using "On Error Resume Next" so that in every situation the code will remain invulnerable. However, you might have noticed in my second post here that my written code is very much fragile and will break if it fails to find class name anywhere in the table. I could have handled it if two class elements are there by using "with statement" in the later expression in combination with "length" and "item" property. I can't do it here because of single class element. Could you please take a look how can it be if i want to use "with" statement along with "length" and "item" property in my below code. I tried but this is not the way you know:
Sub Tabledata()
    With http
        .send
    For Each data In html.getElementsByClassName("linkcell")
        With data
            If .Length Then x = x + 1: Cells(x, 1) = .item(0).innerText
            If .Length Then Cells(x, 2) = .item(0).NextSibling.innerText
    Next data
No matter using a For Each loop :
without any element, the loop directly ends …
[Just try next code with "linkcellS" for example.]
So in this case it's just a misobservation of the object model !
As data variable is not a collection but just an element
so without a length property …
For Each element In collection : length property on collection,
not under element as you can foresee in VBE Locals window …
Your code amended :​
Sub Tabledata()
    Dim oDoc As New HTMLDocument, oCell As HTMLTableCell, R&
    ActiveSheet.UsedRange.Clear
With New XMLHTTP60
    .send
     oDoc.body.innerHTML = .responseText
For Each oCell In oDoc.getElementsByClassName("linkcell")
    R = R + 1
    Cells(R, 1).Resize(, 2).Value = Array(oCell.innerText, oCell.nextSibling.innerText)
    Set oDoc = Nothing
This thread will be definitely great reference for scraping web data .. Thanks a lot for both of you
Best Regards
You're welcome Yasser !
Same result but pointing and checking the collection :​
Sub TableData2()
    Dim oDoc As New HTMLDocument, N&, R&
With New XMLHTTP60
    .send
With oDoc.getElementsByClassName("linkcell")
'   If .Length Then
         For N = 0 To .Length - 1
            R = R + 1
            Cells(R, 1).Resize(, 2).Value = Array(.Item(N).innerText, .Item(N).nextSibling.innerText)
'   End If
    Set oDoc = Nothing
Try with an non existing class like"linkcellS", no issue …
Obviously you must notice the convenience of For Each.
Hats off to you, Marc L. You are just awesome!!! Sorry, YasserKhalil for creating a sub-thread within your thread. Basically, it is hard for me to control myself from erecting any question specially when I get in contact with Marc L.
