Message Box, count total of parts in each column
Kmahraz
Hello All,
I have to compare two columns containing string data using VBA, the goal is to return the items not in in list A. The code works, but i would like to see if i can get some help to have a message box that calculate the total of each column and return the values.
SAP DATA : xxx
Items Not in A lists: xxxx
DW PARTS: xxxx
This list is going to be updated each month and I want to be able to compare items instantly.
Best,
Karim
Sub Button1_Click()
Dim stNow As Date
stNow = Now
Dim varr As Variant
varr = Range("A2:A" & Range("A" & Rows.Count).End(xlUp).Row).Value
Dim arr As Variant
arr = Range("I3:I" & Range("I" & Rows.Count).End(xlUp).Row).Value
Dim x, y, match As Boolean
For Each y In arr
    match = False
    For Each x In varr
        If y = x Then match = True
    Next x
    If Not match Then
        Range("B" & Range("B" & Rows.Count).End(xlUp).Row + 1) = y
Range("B1") = "Items not in A Lists"
Range("B" & Range("B" & Rows.Count).End(xlUp).Row + 1) = "Items not in I Lists"
'Dim arr As Variant
arr = Range("A3:A" & Range("A" & Rows.Count).End(xlUp).Row).Value
'Dim varr As Variant
varr = Range("I3:I" & Range("I" & Rows.Count).End(xlUp).Row).Value
'Dim x, y, match As Boolean
For Each x In arr
    match = False
    For Each y In varr
        If x = y Then match = True
    Next y
    If Not match Then
        Range("B" & Range("B" & Rows.Count).End(xlUp).Row + 1) = x
Debug.Print DateDiff("s", stNow, Now)
  • MPCMaterialMasterFile.xls
Hi !
As per forum rules :
• Any crystal clear explanation ?
• Any attached workbook with a desired result sample ?
For a total, think about Excel functions …
Hi:
Is this what you are looking for , If you click on the button it will display the totals as a message box.
Hello Nebu
Sorry for my late response i was out of the country, that's exactly what i was looking for, really appreciate it.
Karim
