Comparing 2 Columns with Values, Blanks & "0"
Hello to you all! Need some help today with Column Comparison.
Basically i am comparing to 2 columns with varied status including Blanks & "0"s...
I have used basic If Function to use values from Column C by default and when it is Blank use values from Column B. and produce result as TBD when both column values are Blank.
But my results are affected when Column C has 0's in it. Any help with resolving / simplifying the IF statement will be of great help! thank you.
Cheers
RkR
  • Column Compare.xlsx
