Comparing two TOCs using Pivot
Perry Simpson
Hi All,
Not new to pivot tables, but my use of them is very basic. I would like to compare two sets of document "Table of contents" - These have been simply copied from two separate word documents and placed in individual worksheets, called TOC 1 and TOC 2.
Each file contains the same four columns: ID, Title, Page Number, and Sub-ystem.
What I would like to do is identify the differences between the two tables using pivot. The types of changes I would like to capture is:
1: Where the title text has a different "ID"
2: Where title has been altered (e.g. & has been replaced by "and')
3: Titles that do not exist in either TOC (i.e. specific content to the respective document)
4: and so on ...
I have assumed that a pivot would be the best way to do this, but I am always open to new ideas and trying something different ... I have uploaded the work book (EBS Compare.xlsx).
Thank you in advance.
Perry
  • EBS Compare.xlsx
Hi:
Find the attached.
Click on the Run button on sheet2 . The code will compare sheet 1 and sheet 2 and will flag it matching or not matching. Hope this is what you are looking for.
Note:In VBE - tools- references add Microsoft Scripting runtime if the macro is throwing any error.
  • EBS Compare.xlsm
HI Nebu,
Thank you for the response using VBE - When I run this macro the following pop-up appears with the following message:
Compile Error:
Can't find project or library
(Module1 2:4)
Not sure if this is what you meant with your note at the end.
What do I need to do to clear this error.
Perry
