Concatenate occurrences of cell values found within a range
JCTalk
Hiya,
Having trouble with this one. I've looked all over and been unable to make anything I've found work for me.
I have a lookup spreadsheet with computer names on it in one column, and a list of users that have logged on in the adjacent column (separated by commas), which is a mix of USER IDs and Normal Names.
On my main spreadsheet I have two columns, one the name of the user, and the other the USER ID of the user.
I have created a new column on my main spreadsheet, and I want to basically search for the USER ID of each user on the lookup spreadsheet, and return every computer name that they have used in a concatenated list (comma separated).
I'm looking for a formula for this (can be an array formula). Ideally I don't want to have to use helper columns / cells.
I have attached an example workbook.
Thanks for your help in advance.
  • BookOne.xlsx
Hi Chihiro.
Thanks for your reply. Last night I came across a user function someone had created that did exactly what I needed.
Cheers
