I am using below VBA code to control 2 slicers from 2 Pivot table with 2 different data sources. However when i make a selection in slicer i am receiving error message 1004 error message. My Slicer names are Category, Brand and Manufacturer. Can anyone please help me wfind out whats causing the problem.
Dim mbNoEvent As Boolean
Private Sub Workbook_SheetPivotTableUpdate(ByVal Sh As Object, ByVal Target As PivotTable)
Dim oScSlicer_Brand As SlicerCache
Dim oScSlicer_Manufacturer As SlicerCache
Dim oScSlicer_Category As SlicerCache
Dim oSc As SlicerCache
Dim oPT As PivotTable
Dim oSi As SlicerItem
Dim bUpdate As Boolean
If mbNoEvent Then Exit Sub
mbNoEvent = True
bUpdate = Application.ScreenUpdating
For Each oSc In ThisWorkbook.SlicerCaches
For Each oPT In oSc.PivotTables
If oPT.Name = Target.Name And oPT.Parent.Name = Target.Parent.Name Then
If oSc.Name Like "*Slicer_Category*" Then
Set oScSlicer_Category = oSc
ElseIf oSc.Name Like "*Slicer_Brand*" Then
Set oScSlicer_Brand = oSc
ElseIf oSc.Name Like "*Slicer_Manufacturer*" Then
Set oScSlicer_Manufacturer = oSc
Exit For
If Not oScSlicer_Category Is Nothing And Not oScSlicer_Brand Is Nothing And Not oScSlicer_Manufacturer Is Nothing Then Exit For
If Not oScSlicer_Category Is Nothing Then
If Mid(oSc.Name, 7, 3) = Mid(oScSlicer_Category.Name, 7, 3) And oSc.Name <> oScSlicer_Category.Name Then
oSc.SlicerItems(oSc.SlicerItems.Count).Selected = True
For Each oSi In oScSlicer_Category.SlicerItems
If oSc.SlicerItems(oSi.Value).Selected <> oSi.Selected Then
oSc.SlicerItems(oSi.Value).Selected = oSi.Selected
If Not oScSlicer_Manufacturer Is Nothing Then
If Mid(oSc.Name, 7, 3) = Mid(oScSlicer_Manufacturer.Name, 7, 3) And oSc.Name <> oScSlicer_Manufacturer.Name Then
For Each oSi In oScSlicer_Manufacturer.SlicerItems
If Not oScSlicer_Brand Is Nothing Then
If Mid(oSc.Name, 7, 3) = Mid(oScSlicer_Brand.Name, 7, 3) And oSc.Name <> oScSlicer_Brand.Name Then
For Each oSi In oScSlicer_Brand.SlicerItems
mbNoEvent = False
Application.ScreenUpdating = bUpdate
