Converting Currency in to Words
Sumesh
I have an excel macro which is being used for converting the currency in to words. But it is not working in the new versions of excel (2010 and above). Please help me in providing with a macro which works in latest versions of Excel.
Find below is the existing macro for your reference.
' Main Function *
Function SpellNumber(ByVal MyNumber)
Dim Dollars, Cents, Temp
Dim DecimalPlace, Count
ReDim Place(9) As String
Place(2) = " Thousand "
Place(3) = " Million "
Place(4) = " Billion "
Place(5) = " Trillion "
' String representation of amount
MyNumber = Trim(Str(MyNumber))
' Position of decimal place 0 if none
DecimalPlace = InStr(MyNumber, ".")
'Convert cents and set MyNumber to dollar amount
If DecimalPlace > 0 Then
Cents = Left(Mid(MyNumber, DecimalPlace + 1) & "000", 3)
' Cents = GetHundreds(Left(Mid(MyNumber, DecimalPlace + 1) & "00", 3))
MyNumber = Trim(Left(MyNumber, DecimalPlace - 1))
Count = 1
Do While MyNumber <> ""
Temp = GetHundreds(Right(MyNumber, 3))
If Temp <> "" Then Dollars = Temp & Place(Count) & Dollars
If Len(MyNumber) > 3 Then
MyNumber = Left(MyNumber, Len(MyNumber) - 3)
MyNumber = ""
Count = Count + 1
Loop
Select Case Dollars
Case ""
Dollars = " "
Case "One"
Dollars = "Omani Rial One"
Case Else
Dollars = "Omani Rial " & Dollars
End Select
Select Case Cents
Case ""
Cents = " "
Case "One"
Cents = " and One Baizas"
Case Else
Cents = " and " & Cents & " Baizas"
End Select
SpellNumber = Dollars & Cents & " only"
End Function
' Converts a number from 100-999 into text *
Function GetHundreds(ByVal MyNumber)
Dim Result As String
If Val(MyNumber) = 0 Then Exit Function
MyNumber = Right("000" & MyNumber, 3)
'Convert the hundreds place
If Mid(MyNumber, 1, 1) <> "0" Then
Result = GetDigit(Mid(MyNumber, 1, 1)) & " Hundred "
'Convert the tens and ones place
If Mid(MyNumber, 2, 1) <> "0" Then
Result = Result & GetTens(Mid(MyNumber, 2))
Result = Result & GetDigit(Mid(MyNumber, 3))
GetHundreds = Result
End Function
' Converts a number from 10 to 99 into text. *
Function GetTens(TensText)
Result = "" 'null out the temporary function value
If Val(Left(TensText, 1)) = 1 Then ' If value between 10-19
Select Case Val(TensText)
Case 10: Result = "Ten"
Case 11: Result = "Eleven"
Case 12: Result = "Twelve"
Case 13: Result = "Thirteen"
Case 14: Result = "Fourteen"
Case 15: Result = "Fifteen"
Case 16: Result = "Sixteen"
Case 17: Result = "Seventeen"
Case 18: Result = "Eighteen"
Case 19: Result = "Nineteen"
Case Else
End Select
Else ' If value between 20-99
Select Case Val(Left(TensText, 1))
Case 2: Result = "Twenty "
Case 3: Result = "Thirty "
Case 4: Result = "Forty "
Case 5: Result = "Fifty "
Case 6: Result = "Sixty "
Case 7: Result = "Seventy "
Case 8: Result = "Eighty "
Case 9: Result = "Ninety "
Case Else
End Select
Result = Result & GetDigit _
(Right(TensText, 1)) 'Retrieve ones place
GetTens = Result
End Function
' Converts a number from 1 to 9 into text. *
Function GetDigit(Digit)
Select Case Val(Digit)
Case 1: GetDigit = "One"
Case 2: GetDigit = "Two"
Case 3: GetDigit = "Three"
Case 4: GetDigit = "Four"
Case 5: GetDigit = "Five"
Case 6: GetDigit = "Six"
Case 7: GetDigit = "Seven"
Case 8: GetDigit = "Eight"
Case 9: GetDigit = "Nine"
Case Else: GetDigit = ""
End Select
End Function
Sumesh
Sumesh
It works fine for me in both Excel 2010 and 2013
The code must be in a Code Module, not in a Worksheet module,
see below
Can you tell us what is wrong?
Is it not working, giving the wrong answer or something else
maybe a screen capture or more detail will help us
