    Hi Guest,
    Yours,
    Chandoo
  2. Hi All
Count color cell both (Manual and CF) with VBA
Discussion in 'VBA Macros' started by Jagdev Singh, Aug 11, 2017.
  1. Jagdev Singh
    Jagdev Singh Active Member
    598
    Hi Experts,
    Please let me know if this is possible or not. I have a sheet which contains red cell with both Manual and Conditional Formatting red colored cell. I want to count the number of cells with both options available in the sheet.
    In the attached sample column A is the manually added red color cell. The column B is the conditional formatting driven red colored cells. The output of this is total number of cells available in the sheet i.e. 3.
    Kindly let me know if this is feasible or not.
    JD
  2. Chihiro
    Chihiro Well-Known Member
    3,463
    If using manual format, use one of UDFs that's out there.
    https://support.microsoft.com/en-us...f-cells-with-specific-cell-color-by-using-vba
    Unfortunately, there isn't direct way to count CF color using UDF.
    Alternatives are.
    1. Write enter operation in VBA, then have the code put back the value to desired location. I believe this is only possible for Excel 2010 or later.
    2. Since it's CF, there must be underlying logic that determines color. So, count the values that meet the condition in range using COUNTIF, etc.
  3. p45cal
    p45cal Well-Known Member
    763
    Chihiro is correct; you can write a function to count colours including conditionally formatted colours (using .DisplayFormat) and it will work when called by another sub, it just won't work when you try to call it from a worksheet cell. Most Excel MVPs consider this to be a bug. .DisplayFormat is only available from Excel 2010 onwards.
    In the attached, I've written a sub to count colours whether from CF or manually added, which you can call manually, or by clicking the button on the sheet, or you could assign it a hot-key combination.
    It works like this:
    1. Select the area(s) you want to count the colours in. If you're selecting several non-contiguous areas make sure they don't overlap else you might get colours counted more than once.
    2. Make the last selection the single cell whose colour you want to count. Hold the Ctrl key down while selecting the last cell (and to select non-contiguous areas).
    3. Run the macro.
    The count will appear in the cell immediately to the right of the single coloured cell you selected at the end.
    The code:
    Code (vb):
    Sub ColourCount()
    Set TheRange = Selection
    With TheRange.Areas(TheRange.Areas.Count)
      lCol = .DisplayFormat.Interior.Color
      Set OutPutCell = .Offset(, 1) 'this is what decides which cell the count appears in.
    For i = 1 To TheRange.Areas.Count - 1
      For Each rCell In TheRange.Areas(i).Cells
        If rCell.DisplayFormat.Interior.Color = lCol Then vResult = 1 + vResult
      Next rCell
    OutPutCell.Value = vResult
    'MsgBox vResult
  4. Jagdev Singh
    598
    Hi p45cal and Chihiro,
    Thanks for the above information and code. This is really helpful. Appreciated your input on this!
    JD
Share This Page
