Hi all,
I have 2 excel sheets (Sheet A and Sheet B) and I would like to assign a VBA code to create a hyperlink in Sheet A. The hyperlink will be created in cells (column B Sheet A) when there is a match for Xi in these two Sheets.
I have created a loop function in order to compare the two columns in Sheet A and Sheet B. I am not sure how is the VBA syntax in order to create the hyperlink in cells Sheet A when there is a match for the Xi variable.
Could you please help me?
Thank you in advance for your help.
Georgia.
Georgia.
