    Hi Guest,
    Yours,
    Chandoo
  2. Hi All
Creating a chart with different data point formats
Discussion in 'Discuss Data Visualizations and Charting' started by SDV, May 17, 2017.
  1. SDV
    SDV New Member
    16
    Hi everyone!
    You have given me incredible solutions to my previous question, and I hope you can once again help me out here!
    1. I want to create a chart that looks like the attached PDF file. I used scatter charts, and added labels as text boxes for the x-axis. So far, so good.
    2. I have differentiated the data points (colour, shape, outline) based on performance, functional and leadership ratings, and added + or - to show change from the previous year.
    3. I changed the data points one by one to get them the way I wanted, but now I have to do it for hundreds of data points.
    Q1. Is there any way to set automatic (or dynamic) chart settings where the data points will get formatted depending on the data used?
    Q2. Alternatively, is it possible to use formulas to change data points?
    Thank you!
    SDV
  2. Hui
    Hui Excel Ninja Staff Member
    10,318
    It can be done
    You will need 192 Helper columns for each series
    that is 3 x 4 x 4 x 2 x 2
    Set them up and populate them as appropriate
    I will try and get to this in the next day or so, unless somebody else jumps in!
    Yes it will handle hundreds of data points per each series
  3. Hui
    10,318
    Here is a start
    So you will have to manually format 191 more series
    Then add your data
    then enjoy
    See attached file for the layout
    Thomas Kuriakose likes this.
  4. SDV
    SDV New Member
    16
    Hi Hui,
    Do you mean I have to manually format 192 data points? When I add data to any of the cells, many more data points are added to the chart - I don't need 192 data points on the chart, just 1 point to represent 1 value.
    I found a VBA that comes close to what I'm looking for:
    http://www.clear-lines.com/blog/post/Excel-ScatterPlot-with-labels-colors-and-markers.aspx
    I am trying to edit that to make it run on my data, with more formatting options.
    SDV
  5. Hui
    10,318
    You have 192 combinations of data
    3 x 4 x 4 x 2 x 2 = 192
    So you need a series for each combination
    You have to format each series once
    Each series can have as many points as you want
    You could write a macro to do it for you if you want
Share This Page
