Cross Post:If condition for a powerpivot
Balajisx
Hi Team,
I have asked the same question in a different forum. link below
https://www.excelforum.com/excel-general/1190900-if-condition-for-a-range.html#post4689244
1. I have a raw data which contains the quality details like agent name, files audited ,pass or fail . I have converted this data to a table and added to data model.
2. Using simple DAX function, I have created measures for Volumes audited, Quality %, How many are critical, and How many or non critical errors.
3. By using the data model I have created a monthly summary pivot table in the summary tab of my file which shows the monthly qualilty scores for each individuals.
*******Now real scnerio is to find the Quality Improvement phase, by using the same data model, I have to build a pivot table which shows the latest 10 weeks quality score for each agents and I need to find which phase they are belongs to based on the below criteria. ****
QIP 1 - if the agent quality score fall below 95 % for consecutive 2 weeks then he will be in QIP 1
QIP 2 - if the agent quality score fall below 95 % for consecutive 5 weeks then he will be in QIP2
Call to Action : if the agent quality score fall below 95 % for consecutive 9 weeks then he will be in CTA.
I am not able to find a solution since it is in a powerpivot. Is there any way to do this?
Attached is the sample file for your reference.
Thanks in advance,
Balajisx
  • Sample 2.xlsb
What you are looking to do is impossible with PivotTable, as per your data model and Pivot Table design.
If you are willing to accept formula solution. Do something like...
=IFERROR(CHOOSE(MATCH(MAX(FREQUENCY(IF(L8:T8<>"",IF(L8:T8<0.95,COLUMN(L8:T8))),IF(L8:T8>=0.95,COLUMN(L8:T8)))),{2,5,9},1),"QIP 1", "QIP 2", "Call to Action"),"")
Confirmed as array (CTRL + SHIFT + ENTER)
