Custom Filter macro not working
Excelophobe
Hi all - please help. :)
I need a macro that filters a table based on whether the date in the DATE column is equal to today's date or in the future.
Essentially what i need to do is to filter out all entries that are due by today's date or in future, and delete them. What i should be left with are all entries from yesterday and further back in time.
I tried to record a simple macro that selects Custom Filter on DATE column (column 4) and selects "is after or equal to" and today's date from the calendar. Today's date has to be selected/automated as this is for a recurring report that is to be produced on multiple days of the week.
    ActiveSheet.ListObjects("Table6").Range.AutoFilter Field:=4, Criteria1:= _
        ">=24/04/2015", Operator:=xlAnd
This code does not return the required data. Even though i recorded the correct procedure while recording the macro, the macro itself does not pick up what options i have selected in Custom Filter.
Please help!
Best regards,
E.
The issue occurred due to date format.
Try this.
Sub Macro2()
        ">=" & DateSerial(2015, 4, 24)
I think the problem is the addition of the Operator parameter , since you are not using 2 criteria ; an Operator parameter is required only when you are using multiple criteria.
Without it , the following should work :
">=24/04/2015"
Of course , I assume your date format is dd/mm/yyyy
If you want the filter to be related to today's date , you can use :
">=" & Date
where Date is a VBA function which returns today's date.
Here's no role of "Operator:=xlAnd" either it be or not.
Date format must be same as per system date format.
OP code failed in due course his date format doesn't match with the system date format. In a workaround following will also do the job.
">=24/April/2015", Operator:=xlAnd
where system date format is "DD/MMM/YY"
However ">=" & Date or ">=" & DateSerial(2015, 4, 24) should be used to get rid of the error.
