    Hi Guest,
    Yours,
    Chandoo
  2. Hi All
Cut and Paste Rows using variable row count
Discussion in 'VBA Macros' started by KathrynJ, Mar 20, 2017.
  1. KathrynJ
    KathrynJ New Member
    8
    I want to find all the cells in column A that begin with "OM", and then cut the entire rows and move (paste) them into a second worksheet. But each month the row count will change - so I can't use a simple range of rows (i.e., rows 100-200). They will vary from month to month. Is there a macro that will work?
  2. Monty
    Monty Well-Known Member
    635
    KathrynJ
    Welcome to forum.
    Sample file will provide you targeted solution.
    Arpanakumar and jamesexcel1970 like this.
  3. Monty
    635
    Try this!
    Code (vb):
    Sub MONTY()
    Dim lrow As Long
    lrow = Range("A" & Rows.Count).End(xlUp).Row
    Rows("1:1").Select: Selection.AutoFilter
    ActiveSheet.Range("$A$1:$I$" & lrow).AutoFilter Field:=1, Criteria1:="OM"
    Range("A2:I" & Cells(Rows.Count, "A").End(xlUp).Row).SpecialCells(xlCellTypeVisible).Copy
    Worksheets("Sheet2").Select
    Range("A" & Rows.Count).End(xlUp).Offset(1, 0).PasteSpecial
  4. Monty
    635
    Here is the file ...change sheet names as per your requirment!
  5. KathrynJ
    KathrynJ New Member
    8
    This works up to a point. I actually want to remove/cut the rows from the first sheet, not simply copy them. But I can't seem to get that to work.
    Here's my code:
    Dim lrow As Long
    lrow = Range("D" & Rows.Count).End(xlUp).Row
    Sheets("Sheet1").Select
    Rows("6:6").Select: Selection.AutoFilter
    ActiveSheet.Range("$D$6:$D$" & lrow).AutoFilter Field:=1, Criteria1:="OM*"
    Range("D7:S" & Cells(Rows.Count, "D").End(xlUp).Row).SpecialCells(xlCellTypeVisible).Cut
  6. Monty
    635
    Hello
    From my code change copy to cut....You are done.
    Arpanakumar likes this.
  7. KathrynJ
    KathrynJ New Member
    8
    When I change copy to cut, I get an error on the last row: "PasteSpecial method of Range class failed".
    Any other suggestions?
  8. KathrynJ
    KathrynJ New Member
    8
    Here's a way I made it work by adding code to delete the rows from sheet1.
    Dim lrow As Long
    Range("D7:S" & Cells(Rows.Count, "D").End(xlUp).Row).SpecialCells(xlCellTypeVisible).Copy
    Range("D7:S" & Cells(Rows.Count, "D").End(xlUp).Row).SpecialCells(xlCellTypeVisible).Delete
Share This Page
