Hi all,
I am trying to use the referenced code on a spreadsheet used for DataEntry; only two cells are to work with the referenced. The code was obtained from your friends at http://www.contextures.com/xlDataVal11.html (great tutorial btw), with a minor tweek on my behalf to limit it's use to two cells on my DataEntry spreadsheet.
The first cell works correctly, while the second cell does NOT show the drop-down list pertinent to that second cell (ie. it comes out blank)...
The DV are derived from Dependent Dynamic Ranges against Excel Tables in other worksheets, and both work correctly.
The code I am using is:
I am not an experienced VBA programmer, and would appreciate all the help / guidance you can provide.
Kind regrads
New forum member DMurray3
'Data Validation Drop Downs With Combo Box Using Named Ranges
'from www.contextures.com
Private Sub Worksheet_BeforeDoubleClick(ByVal Target As Range, _
Cancel As Boolean)
'*****To Define the cells where the DV w/CBx will be applied*****
If Not Intersect(Target, Target, Range("H3,H5")) Is Nothing Then
Dim str As String
Dim cboTemp As OLEObject
Dim ws As Worksheet
Set ws = ActiveSheet
Set cboTemp = ws.OLEObjects("FVIngresoCombo")
With cboTemp
'clear and hide the combo box
.ListFillRange = ""
.LinkedCell = ""
.Visible = False
On Error GoTo errHandler
If Target.Validation.Type = 3 Then
'if the cell contains a data validation list
Cancel = True
'get the data validation formula
str = Target.Validation.Formula1
str = Right(str, Len(str) - 1)
With cboTemp
'show the combobox with the list
.Visible = True
.Left = Target.Left
.Top = Target.Top
.Width = Target.Width + 15
.Height = Target.Height + 10
.ListFillRange = str
.LinkedCell = Target.Address
cboTemp.Activate
'open the drop down list automatically - this works for the 1st cell (h3) but not for the second cell (h5)
Me.FVIngresoCombo.DropDown
errHandler:
Exit Sub
Dim str As String
Dim ws As Worksheet
If Application.CutCopyMode Then
'allow copying and pasting on the worksheet
GoTo errHandler
With cboTemp
.Top = 10
.Left = 10
.Width = 0
.ListFillRange = ""
.LinkedCell = ""
.Visible = False
.Value = ""
errHandler:
Exit Sub
'Optional code to move to next cell if Tab or Enter are pressed
'from code by Ted Lanham
'---NOTE: if KeyDown causes problems, change to KeyUp
Private Sub FVIngresoCombo_KeyDown(ByVal _
KeyCode As MSForms.ReturnInteger, _
ByVal Shift As Integer)
'Hide combo box and move to next cell on Enter and Tab
Select Case KeyCode
Case 9 'Tab
ActiveCell.Offset(0, 1).Activate
Case 13 'Enter
ActiveCell.Offset(1, 0).Activate
Case Else
'do nothing
End Select
Kind regrads
