    Hi Guest,
    Yours,
    Chandoo
  2. Hi All
Delete first five cells in a row based on two conditions
Discussion in 'VBA Macros' started by freshtomm, Mar 19, 2017.
  1. freshtomm
    freshtomm Member
    32
    i need to delete first five cells (A:E) in a row in case that cell in column A contains value higher than 2016 and cell in column B contains value higher than 15. Both conditions must be true to delete part of that row. Is that possible?
    Thanks.
  2. vletm
    vletm Well-Known Member
    2,546
    Q1: Do You really want to 'delete' or just 'clear' those cells; "A1:E5"?
    Q2: How many times would needed 'delete' to do; once or as many times as both conditions are true?
  3. freshtomm
    freshtomm Member
    32
    Every week i get database, and i need to delete every record that is not 2016 in clolumn A and from 1 to 15 in column B. But only columns Axxx:Exxx bacause in further columns i have formulas.
    Q1: I want to delete cells and data from below move up.
    Q2: I need to do that as many times as both conditions are true.
    Thanks.
    Derek McGill likes this.
  4. YasserKhalil
    YasserKhalil Active Member
    576
    Try this
    Code (vb):
    Sub Test()
        Dim i As Long
        For i = 1 To Cells(Rows.Count, 1).End(xlUp).Row
            If Cells(i, 1).Value > 2016 And Cells(i, 2) > 5 Then
                Cells(i, 1).Resize(, 5).Delete Shift:=xlUp
    If you need to delete the cells to the left .. Change xlUp part to xlToLeft
  5. vletm
    2,546
    @freshtomm
    1st You wrote that:
    i need to delete first five cells (A:E) in a row in case that cell in column A contains value higher than 2016 (no 2015, yes 2017) and cell in column B contains value higher than 15 (no 14, yes 16).
    Now You wrote that:
    Every week i get database, and i need to delete every record that is not 2016 in clolumn A (yes 2015, yes 2017) and from 1 to 15 in column B (yes 14, no 15).
    >>> Did rules change or what happened?
    Are those A- & B-column values numbers?
  6. Derek McGill
    Derek McGill Active Member
    129
    This might be what you want :-
    ( Use on a copy of your file )
    Code (vb):
    Sub MoveUp_5_Cells()
    Dim Last_Row As Long
    Dim i As Long
    Last_Row = ActiveSheet.Range("A65536").End(xlUp).Row
    Do Until Last_Row = 1
    If Cells(Last_Row, 1).Value > 2016 And Cells(Last_Row, 2) > 15 Then
       Cells(Last_Row, 1).Resize(, 5).Delete Shift:=xlUp
       Last_Row = Last_Row - 1
    Loop
    freshtomm likes this.
  7. freshtomm
    freshtomm Member
    32
    My mistake, B contains value higher than 15 is right. (no 14, yes 16)
    Both are numbers.
  8. freshtomm
    freshtomm Member
    32
    Both codes works well, but way to slow on that large database.
    Thanks anyway.
  9. Marc L
    Marc L Excel Ninja
    3,027
    Hi !
    As Excel is not a database software,
    in case of serious database, use Access instead …
    If at least you join a sample workbook,
    a faster way using formula in VBA may be shared !
    A trick : column F empty may help …
  10. Derek McGill
    129
    Try to give as much information at the start to help the people who want to help you.
  11. Marc L
    Marc L Excel Ninja
    3,027
    Yasser, Derek,
    here it is just the first VBA rule to keep in mind : TEBV (1)
    Better than using a loop and working cell by cell or row by row
    (the more rows, the slower) is to use Excel basics !
    • In a helper column, F as here it's just column A to E,
    just apply an easy formula (at very beginner level !)
    testing the cells, example in F2 : =AND(A2>2016,B2>15)
    Result displays FALSE for a row to keep and TRUE if to be deleted …
    • Sort range from column A to F on column F in ascending way :
    the rows to delete (TRUE) are now at the end of range …
    • Use Find or MATCH Excel function on column F to get the first TRUE
    so the first row to delete.
    • From this first row to delete until the last row, use Range.Clear method
    as it is faster than Delete and 'cause all rows to delete are yet at the end,
    no needing to move up any row under ! Clear too column F …
    (1) Think Excel Before VBA ! That's it ! Whatever you live in Egypt or in Bulgaria …
    Edit : after a private message from Bulgaria (yes Chandoo is World Wide !)
    I must precise : this post is a reminder to use Excel basics
    within a VBA code as it can be faster than a classic VBA loop …
Share This Page
