I have the following work sheet. I have 4 input questions and when answered based on the inputs will result in a determined answer. Need help. I tried an if or statement but it never resulted in another answer.
It looks like the result is the characters following the final space in the Method
If that is the case then you can simply use
B7: =IFERROR(IF(LEN(B5)-LEN(SUBSTITUTE(B5," ",""))>1,RIGHT(B5,LEN(B5)-FIND(" ",B5,FIND(" ",B5)+1)),RIGHT(B5,LEN(B5)-FIND(" ",B5))),"TN")
copy across
Or you could setup a small lookup
How can i have the answer placed in a colored box?
Add a text box using Insert, Textbox or any Shape
Click the text textbox/shape then in the formula bar put a reference to the cell containing the answer
