doughnut chart help
HanSam
Is it possible to create multiple doughnut charts from only one pivot table and show only specific series per doughnut?
Say I want to show the different bu % per region on the file attached.
  • Doughnut Sample.xlsx
Add a chart
Then add Business to the Filter section of the Pivot Table Fields
You can now select the business directly on the chart or in the PT
hi hui,
Thanks for the response. However I need multiple doughnut charts to show at the same time. It would also include a filter that will control the contents of the PT, thus should reflect on the doughnut charts too
