I've got two worksheets called venue and note in Excel 2013. I've created dynamic hyperlinks in the note worksheet to refer to venues in the venue worksheet by using the hyperlink function + index and match + cell functions.
In the note worksheet, you have to enter the venue ID and it generates the hyperlink to the venue in the Venue worksheet by looking up it's name using the Venue ID value and then I get the cell reference of the Venue name cell in the Venue worksheet to generate the dynamic hyperlink.
However, the hyperlinks are only working for venue ID's from 1 to 15 even though I have venues with Venue ID's higher than 15 in the Venue worksheet.
This is some sample data I am using in the note worksheet.
The venue ID is in cell j2, VenueName is in m2, Venue name cell reference is in cell l2 and the hyperlink is in cell k2:
VenueID
18
VenueName
=INDEX(Venue_Name,MATCH(J2,Venue_ID,0))
Venue_Name_CellReference
=CELL("address",INDEX(Venue_Name,MATCH(J2,Venue_ID,0)))
VenueLink
=HYPERLINK(L2,M2)
Thanks,
Tom
VenueID
18
VenueName
VenueLink
=HYPERLINK(L2,M2)
Thanks,
Tom
