Excel 2013 "400" Macro Error Help Needed
skidragon02
I am using the following Macro in Excel 2013 and receiving an error message that simply says "400" and prevents the macro from adjusting my margins appropriately. Does someone know what is causing the problem? Thanks in advance for the help!
Sub Column_Widths()
Dim i As Integer
Dim ws As Worksheet
For i = 3 To 11
  With Sheets(i)
  .Columns("A:A").ColumnWidth = 5.57
  .Columns("B:B").ColumnWidth = 11.71
  .Columns("C:C").ColumnWidth = 8.86
  .Columns("D:D").ColumnWidth = 8.86
  .Columns("E:E").ColumnWidth = 9.43
  .Columns("F:F").ColumnWidth = 2.86
  .Columns("G:G").ColumnWidth = 17#
  .Columns("H:H").ColumnWidth = 7.29
  .Columns("I:I").ColumnWidth = 32#
  .Columns("J:J").ColumnWidth = 32#
  .Columns("K:K").ColumnWidth = 16.29
  .Columns("L:L").ColumnWidth = 7.71
  .Columns("M:M").ColumnWidth = 10.29
  .Columns("N:N").ColumnWidth = 4.86
  .Columns("O:O").ColumnWidth = 7.14
  .Columns("P:P").ColumnWidth = 4.86
  .Columns("Q:Q").ColumnWidth = 6.29
  .Columns("R:R").ColumnWidth = 5.57
  .Rows("3:183").EntireRow.AutoFit
Hmm. Not sure what's the problem. As a work-around, and possible improvement, if you create a template sheet somewhere, you could change the code to be:
Sub Column_Widths()
Dim i As Integer
'Some random sheet that has column widths already set
Worksheets("My template").Cells.Copy
For i = 3 To 11
    With Sheets(i)
      .Cells.PasteSpecial (xlPasteColumnWidths)
One quick thing, you don't happen to have any chart sheets in your workbook? I just noticed that your code says "Sheets(i)", so it's possible a Chart sheet could be selected, which would error out if you try to adjust rows/columns. :)
I don't believe so. I am using formulas and conditional formatting within tables, but nothing beyond that.
When the code errors out , has it completed at least one worksheet ? Or does it error out on the very first sheet ?
I tried out the code , and it does not give any error.
You can comment out the statement :
at the beginning , and see if you get any more informative error message.
There must be some hidden sheets like chart sheet....I tried with your code and it works perfectly.But when I added a chartsheet it threw error. In your code, I replaced 'sheet' with 'worksheet' and it worked.
With Worksheets(i) ' use this code
With Regards
Rudra
In case you are still getting an error, can you add an Error check to find out what the Error description is.
Add this line after "Application.ScreenUpdating = False"
On Error GoTo ErrorChk
and at the end of the code after "Next" add the below lines
exit sub
ErrorChk:
MsgBox Err.Description
Now run your code and you should get a description of the error that you are facing.
Regards!
