    Hi Guest,
    Yours,
    Chandoo
  2. Hi All
Expecting someone to help me create a facebook bot
Discussion in 'The Vault' started by shahin, Mar 10, 2017.
  1. shahin
    shahin Member
    342
    Hi there! Good afternoon. I tried to make a facebook bot to parse the profile links. However, it signs in and parses the content of left-sided bar inconsistently. I can't go further. Could anyone point me in the right direction so that i can rectify my mistakes I've made already in my code and move on. Here is the code:
    Code (vb):
    Sub FBbot()
    Dim http As New MSXML2.XMLHTTP60, html As New HTMLDocument
    Dim topics As Object, topic As Object
    Dim x As Long,strdata As String
    x = 2
    strdata = "email=sth.com&pass=xxx"
    http.Open "POST", "https://www.facebook.com/login.php?login_attempt=1&lwv=110", False
    http.setRequestHeader "Content-type", "application/x-www-form-urlencoded"
    http.send strdata
    html.body.innerHTML = http.responseText
    Set topics = html.getElementsByClassName("_li")(0).getElementsByTagName("a")
    For Each topic In topics
        Cells(x, 1) = topic.innerText
        x = x + 1
    Next topic
  2. Hui
    Hui Excel Ninja Staff Member
    10,455
    I can't really help but as I rarely scrape web sites and have never scraped facebook
    In Facebook right click on what you want and Inspect Element
    Make sure that the Topic and Innertext are the correct fields
    You may also want to see if there are different view panes/windows that you need to look through (I'm not sure of the correct term)
    ThrottleWorks and shahin like this.
  3. shahin
    shahin Member
    342
    Thanks sir for your kind reply. I'm trying to find that out also where I'm making mistakes.
  4. shahin
    shahin Member
    342
    I've got it working with the below code. It is necessary to do one thing manually, though. After running this script, when facebook page opens up, there will be a notification popping up mentioning "Allow" or "Block". Wait a little while to get the buffering done and then Just click on "Allow". That's it. Btw, before running this script make sure "Selenium Type Library" has been added in the reference.
    Code (vb):
    Sub Facebook_crawler()
    Dim driver As New WebDriver
    Dim posts As Object, post As Object
    With driver
        .Start "chrome", "https://www.facebook.com"
        .get "/login.php?login_attempt=1&lwv=111"
        .FindElementByXPath("//*[@id='email']").SendKeys ("someEmail") --Fill in according to your email
        .FindElementByXPath("//*[@id='pass']").SendKeys ("password") --Fill in with your password
        .FindElementByXPath("//*[@id='loginbutton']").Click
        .Wait 800
        .FindElementByXPath("//a[@id='findFriendsNav']").Click
        .Wait 500
    For x = 0 To 50
        driver.ExecuteScript "window.scrollTo(0, document.body.scrollHeight);"
        driver.Wait 500
    Next x
    Set posts = driver.FindElementsByXPath("//div[contains(@class,'friendBrowserNameTitle')]/a")
    For Each post In posts
        i = i + 1
        Cells(i, 1) = post.Text
    Next post
    ThrottleWorks likes this.
  5. shahin
    shahin Member
    342
    Forgot to mention that the above crawler is able to scrape the names of friend request by going to the target page and scrolling down to a certain position.
  6. Hui
    10,455
    Have you tried this in Excel 2016+
  7. shahin
    shahin Member
    342
    Thanks sir Hui, for showing me a new way of doing stuffs. Is it power query? I heard that it can do impossible things. Anyways, I use excel 2013.
  8. Hui
    10,455
    Have a look just in case it's there
  9. shahin
    shahin Member
    342
    Found the solution. Now this scraper is able to harvest all the names from the friend list without manual intervention, as in clicking the "Allow" or "Block" notification. It can automate the whole operation. Don't forget to add "Selenium Type Library" in the reference library before execution. Here is the code:
    Code (vb):
    Sub Test_stth()
    With driver
        .SetPreference "profile.default_content_setting_values.notifications", 2  'This is the line which is able to block the notification
        .FindElementByXPath("//*[@id='email']").SendKeys ("username")     'Input the username
       .FindElementByXPath("//*[@id='pass']").SendKeys ("password")   'Input the password
        .Wait 800
        .Wait 500
    For x = 0 To 50
        driver.Wait 500
    Next x
        i = i + 1
    Next post
    <Edited as requested by user>
    NARAYANK991 likes this.
  10. shahin
    shahin Member
    342
    As I don't have enough privilege to rectify a certain line in the pasted code above, I'm pasting below the modified line. ID should be [@id='email'] not [@id='username']. Now I suppose You don't find any trouble getting the harvested results.
    Code (vb):
Share This Page
