I use ExportAsFixedFormat to save my worksheet in a pdf, using vba code, in excel2013.
Now it runs 3 times longer then in an older version of excel.
Can I fix this ?
Its either that your file is too big - because of data or pivots or conditional formats / OR you've got too many formulas in your file so each time something is changed by your vba the formulas recalculate & it takes longer to do its thing. But can't really give u a 100% answer till I know what the code is & which file it works on. No way to know for sure.
