Extract data to next columns
Puttaswamy
Col A has below data from a1 to a100. i need to copy repeated data to next cols, i.e. to b col, c col, d col and so on....
1
2
3
4
5
1
2
3
4
5
dear friend,
just select your data from A1 to A100, then select towards right side using Shift key (col b, col c, col d,........) and then press CTRL R.
@Puttaswamy
Welcome to Chandoo.org Forum, Glad you are here
Another method you can use the Offset Function
Say your data in A1:A100 and you want to reflect the same value in another columns then
just type in B1 = OFFSET(A1,0,0) now copy the formula and paste in your required columns from Ex. B1:I100
when ever you change any cell value in the A1:A100 it will automatically reflect in another columns
hope it clear, if any issue please inform
SP
