I have a table range, i would like to extract two rows from the range and send mail. Also i need to keep the column header same. I tried using the following
DatatoSend = Union(.Range(.Cells(1, "A"), .Cells(1, "B")), _
.Range(.Cells(c.Row, "A"), .Cells(c.Row , "B")))
But it Picks up one Row Item along with the header column, i want to pick two row items at a time and send mail, so if there are 4 row items. Two mails should go with 1st row header and subsequent rows A1,B1;A2,B2;A3,B4 should be items for first mail and second mail should have A1,B1;A4,B4
Can someone help please... here is the code I am using
Sub SendEmail()
Dim objOutlook As Object
Dim objNameSpace As Object
Dim objMailItem As Object
Dim ws As Worksheet
Dim rngEmailAddress As Range
Dim c As Range
Dim rngAttach As Range
Dim strBody As String
Dim strAttachment As String
Set ws = Sheets("Test Mail") 'Edit the sheet name if required.
With ws
Set rngEmailAddress = .Range(.Cells(2, "B"), .Cells(.Rows.Count, "B").End(xlUp))
Set objOutlook = GetObject(, "Outlook.Application")
On Error GoTo 0
If objOutlook Is Nothing Then
Set objOutlook = CreateObject("Outlook.Application")
Set objNameSpace = objOutlook.GetNamespace("MAPI")
strBody = "<p style='font-family:Calibri;font-size:16'>Dear Team, " & "<br><br>" & _
"<p style='font-family:Calibri;font-size:16'>Please log a ticket for backup failure for the following devices, details as on " & Format(Date, "dd-mm-yyyy")
For Each c In rngEmailAddress
With ws
Set rngAttach = Union(.Range(.Cells(1, "A"), .Cells(1, "B")), _
.Range(.Cells(c.Row, "A"), .Cells(c.Row + 1, "B")))
Set objMailItem = objOutlook.CreateItem(0)
With objMailItem
.To = "email id 1"c.Value
.Subject = "Testing Mail Sending"
.HTMLBody = strBody & RangetoHTML(rngAttach) & "<br>" & .HTMLBody
.Send
DoEvents
Next c
Set c = Nothing
Set rngEmailAddress = Nothing
Set ws = Nothing
Set objMailItem = Nothing
Set objNameSpace = Nothing
Set objOutlook = Nothing
