Extraction of Data from Closed workbooks using vba
raypk
I have a database in one folder. Plz Unzip and see all excel files shown datewise. Can anyone help me in extracting day wise data of parameters in format shown in Monthly tracker sheet.
Please check the format. It should be like if i select one workbook data from only that one will be extracted, if selected 2 data from one and two both so on and so forth till 31 days. i am uploading the the database and monthly tracker.
please help .... I am in urgent need...
thanks in advance
  • DB.zip
Hi
I can help you with the codes, do you know VBA to customize, sry dont have mch time due to work schedule to do it.
The code below would bring a file browser window where you can select your file that has the source data (ReportWbk), and then data is copied from SHEET1 and SHEET2 and pasted in the current file. the ranges are also specified. pls amend codes accordingly for your use. Thx
Sub AutoCopy()
'Copy data automatically
On Error GoTo here
Dim ReportWbk As Workbook 'workbook with report data
Dim Report As String 'name of file with report data
Application.FileDialog(msoFileDialogFilePicker).Show
Report = Application.FileDialog(msoFileDialogFilePicker).SelectedItems(1)
Set ReportWbk = Workbooks.Open(Report)
'Application.ScreenUpdating = False
ReportWbk.Sheets("SHEET1").Activate
ReportWbk.Sheets("SHEET1").Range("a7:ar7", Range("a7:ar7").End(xlDown)).Copy
ThisWorkbook.Sheets("SHEET1").Activate
Cells(7, 1).Select: Selection.PasteSpecial xlPasteValues
Cells(7, 1).Select
ReportWbk.Sheets("SHEET2").Activate
ReportWbk.Sheets("SHEET2").Range("a7:au7", Range("a7:au7").End(xlDown)).Copy
ThisWorkbook.Sheets("SHEET2").Activate
Cells(7, 1).Select
ReportWbk.Close (False)
'Application.ScreenUpdating = True
here:
'MsgBox ("Select the correct file!")
Exit Sub
I haven't tested!
Sub test()
Dim ows As Worksheet, strfile As String, owbk As Workbook
Dim sPath As String, mysheet As String, myday As Integer, fcell As Range
Dim crng As Range
sPath = Application.ThisWorkbook.Path & "\"
strfile = Dir(sPath & "*.xlsx")
If strfile = "" Then MsgBox "No Files found!!!", vbCritical: Exit Sub
Do While strfile <> ""
myday = Split(strfile, "-")(0)
Set owbk = Workbooks.Open(sPath & strfile)
Set crng = owbk.Sheets(1).[A1].CurrentRegion
    For Each ws In ThisWorkbook.Sheets
        Set fcell = crng.Find(ws.Name)
        If Not fcell Is Nothing Then
            With crng
              .Resize(.Rows.Count - 1, 1).Offset(1, fcell.Column).Copy
            With ws
                .Cells(.[A1].CurrentRegion.Rows.Count + 1, myday + 1).PasteSpecial -4104
    owbk.Close False
strfile = Dir
Loop
hi Deepak, can u please do extraction for the first sheet in Monthly tracker excel file ...from the databases files and suggest me the way for other sheets in that monthly tracker please ...i am quite new to vba, excited to learn ...it will definitelyserve as a motivation for me
Oh.I will do. First do the subjected query.
Place all files including master in same folder.
Insert a module in master workbook & copy the code to there.
Also change the below line
With ws
To
 ws.cells(2, myday + 1).PasteSpecial -4104
Hi Deepak ! its just extracting the data from the column no. one more than what i need..
e.g. like i need data from Column O from each workbook, it is extracting data from Column P ...please help
Change it
fcell.Column
To
fcell.Column-1
@raypk Your discussion:
'Extraction of Data from Closed workbooks using vba' ...
Did You mean that 'Do not open workbooks and get data from those?'
If so, that's possible too ... but with 'open', it would be easier.
hi deepak ...
if the same thing can be used with "Vlookup " function please tell how to change for every parameters..please provide the code fors extraction for different sheets
@Deepak ninja please help me out with the same output using vlookup thing...please i was helpless..using vlookup corresponding to cells in column will definitely yeild correct result...plz...please provide code for vlookup in 'for'loop ...many many thnx
@ raypk
Check this..
Sub test1()
Dim strfile As String, owbk As Workbook, c_col As Integer, myrng As Range
Dim sPath As String, myday As Integer, fcell As Range, crng As Range
        With ws
            Set fcell = crng.Find(.Name)
                c_col = .[A1].CurrentRegion.Rows.Count
                Set myrng = .Range(ws.Cells(2, myday + 1), .Cells(c_col, myday + 1))
                myrng = "=VLookup(a2," & crng.Offset(, 2).Address(, , , True) & "," & fcell.Column - 2 & ",0)"
                myrng.Value = myrng.Value
            Set myrng = Nothing
    owbk.Close False
strfile = Dir
Loop
