Extraction problem
Villalobos
I would like to ask that tow to extract only those materials from sheet Data (the data stored in table) to sheet Extraction which are classed as 7920?
This code is extract all columns but I need only the materials (classed as 7920).
Sub Extract()
Sheets("Extraction").Range("E8").CurrentRegion.Clear
Sheets("Data").Range("Táblázat1[#All]").AdvancedFilter Action:=xlFilterCopy, CriteriaRange:= _
Sheets("Data").Range("L8:L9"), CopyToRange:=Sheets("Extraction").Range("E8"), Unique:=True
Sheets("Extraction").Activate
Sheets("Extraction").Range("E8").Select
The sample file is attached to this thread.
Could somebody give me some advice?
Many thanks in advance!
  • sample.xlsm
Hi !
Advanced filter is the right way.
Attach a sample .xlsx workbook (no code) with a source worksheet
and a desired result worksheet …
Sub Demo()
Dim Ws As Worksheet
Set Ws = Worksheets("Extraction")
    Ws.[B8].CurrentRegion.Clear
With Worksheets("Data")
    .[E8].CurrentRegion.AdvancedFilter xlFilterInPlace, .[L8:L9], , True
    .[_FilterDatabase].Columns(1).Copy Ws.[B8]
    .ShowAllData
Ws.Activate:  Set Ws = Nothing
I don't use Range("Táblázat1[#All]") 'cause now I'm under Excel 2003
and this code style works from the 2007 version …
