Hi all:
I am trying calculate number of hours in C5 from two dates with time (A5 = Start date: 04/09/2014 12:00:00 PM & B5 = End date: 05/09/2014 16:00:00 PM).
Requirements:
Regular work hours are 9:00 am to 4:00pm( 9:00 to 16:00 hours)
It should exclude start hour and end hour (only calculate hours between hours mentioned in dates ( e.g. Sep 4, 2014 12:00PM & Sep 5, 2014 16:00, it should count between 12:00 & 16:00 and give me 3 hours, NOT 4 hours.).
It should exclude weekends (sat & sun)
It should exclude stat holidays. I have list of stat holidays in sheet Holidays in column A
It should consider half days work hours which are listed in sheet Holidays column F & G (9:00 to 13:00). I will keep this list in case we change these hours. And Half work days dates are listed in sheet Holidays, column F. I will keep adding/change these dates because every year dates changes like around christmas or so. Basically list will grow like stat holidays list.
I have formula in C5 (copied from elsewhere) but unable to manage it. How to exclude stat holidays and half work days.
2. Second formula I have in F11, read last date/max date from colum B5:B45 (e.g. last date: Nov 20, 14 12:00:00 PM). Then add number of hours from E11 and give me future date and time.
Requirements:
My formula is working now but unable to handle stat holidays and half work day dates.
I do not know if these formulas can be done just in excel or we need vba code. I spent enough time to figure out the solution and burn my mind. Finally decided to ask gurus.
Hopefully, someone will help.
Attached is sample worksheet. Using excel 2003.
Ria
Requirements:
Requirements:
Ria
