Fullscreen with Status Bar using VBA
Vivek D
I've created a dashboard and display it full screen using VBA.
Application.DisplayFullScreen = True
ActiveWindow.DisplayHeadings = False
Application.DisplayFormulaBar = False
However, I would like to display the status bar even in Full screen mode.
Is there a way to do that?
Check this!!!
Sub test()
With Application
    .DisplayFormulaBar = True
    .ExecuteExcel4Macro "SHOW.TOOLBAR(""RIBBON"", true)"
    .WindowState = xlMaximized
    ActiveWindow.DisplayHeadings = True
Check this!!!
Sub test()
With Application
Thanks. That worked! Although I think you meant to write the false instead of true to ensure nothing but just the status bar shows up.
Sub test()
With Application
    .ExecuteExcel4Macro "SHOW.TOOLBAR(""RIBBON"", False)"
[/quote]
