Help for vba code for a formula in two cells
Hi Friends,
I have a sheet where I need a formula(as below) to be inserted in the in column "B" and "C" using a vba code.
Column B = NETWORKDAYS(A2,$D$2)-1
Column C = =IF(B2>90,">90 Days",(IF(B2<6,"0-5 Days",IF(B2<31,"6-30 Days",IF(B2<91,"31-90 Days")))))
Attached sheet for your reference.
Data in column A and D will change every month.
Request your help on this.
  • Sample Chandoo.xlsx
Should be something like
Sub test()
    Range("a2", Range("a" & Rows.Count).End(xlUp)).Offset(, 1).Resize(, 2).Formula = _
    Array("=NETWORKDAYS(A2,$D$2)-1", "=IF(B2>90,"">90 Days"",(IF(B2<6,""0-5 Days"",IF(B2<31,""6-30 Days"",IF(B2<91,""31-90 Days"")))))")
