help me to create uncopyable pdf file using vba macro
santhosh.b
hi friends,
i create pdf file using ExportAsFixedFormat ..but i want to disable copy option in that pdf file or disable right click option in the pdf. is there any options?
You can only do this from with in the PDF file if you have the right software, To try and do this with Excel would mean the PDF file would have to be in Excel and the options to do what you want in Excel are pretty small.
