mave27
Below is VBA Macro Code which uploads Prod images from Desktop Folder onto Worksheet to create Prod Catalog.
I found this useful piece of code from this forum.
The code is Functional ie it works fine, but need some modification.
The code seems to **ALTER** the size of image during upload, which I DON'T want it to.
I have already created standard, uniform size of all images & stored in the folder.
I simply want the code to pick the image & place it on Worksheet, without re-sizing it.
The Image size is 210 px X 150 px. - the code should also adjust size of Row Height & Col Width accordingly.
Anyone care to modify the code to address that specific aspect of it's functionality ie re-sizing & also, ensure ROW / Col height/ Width ?
Thanks in Advance.
Sub InsertPic()
Dim path As String, pic As String, pname As String
Dim lastrow As Long, r As Range
Dim bExists As Boolean
path = "C:\Users\user\Desktop\NewArrivals\images" 'change as req
lastrow = Range("A" & Rows.Count).End(xlUp).Row
For Each r In Range("A2:A" & lastrow)
bExists = False
pic = r.Value
pname = path & pic & ".jpg"
' check existence of file as jpg
If Dir(pname) = vbNullString Then
' check existence of file as png
pname = path & pic & ".png"
If Dir(pname) <> vbNullString Then bExists = True
bExists = True
If bExists Then
Rows(r.Row).RowHeight = 150
With ActiveSheet.Pictures.Insert(pname)
With .ShapeRange
.LockAspectRatio = msoTrue
.Height = 100
.Width = 100
.Left = Columns("E").Left + Columns("E").Width / 2 - .Width / 2
.Top = Rows(r.Row).Top + Rows(r.Row).Height / 2 - .Height / 2
r.Offset(0, 2).Value = pic
Cells(r.Row, "E") = "**** File Not Found *****"
Thanks in Advance.
