Jagdev Singh
Hi Experts
I need your help to add few more functionality in the below code. The code is working well. I have created the macro excel file with this code. The code helps me to move specific column data from one sheet to another in the macro file. What I have to do here is copy the Raw data from the master sheet file and place it in the Raw tab of the macro file and run it. The result gets saved in the next tab named “Result” in the macro file.
Is it possible to open this macro file first and then open the master sheet from which the Raw data is used instead of coping it and pasting it in the macro file. I mean the code should directly refer to the master sheet raw data tab as an input and create a new workbook and place all the output in it.
Please let me know if this is possible.
JD
Sub CopyColumnByTitle()
Sheets("Result").Cells.ClearContents
Range("G2:O60000").Interior.ColorIndex = 0
ActiveWorkbook.Worksheets("Raw").Activate
Dim SearchCols(14) As String
SearchCols(0) = "Facility_name"
SearchCols(3) = "Country"
SearchCols(4) = "TSI"
SearchCols(5) = "Currency"
SearchCols(6) = "Cyclone"
SearchCols(7) = "Drought"
SearchCols(8) = "Earthquake"
SearchCols(9) = "Fire"
SearchCols(10) = "Flood"
SearchCols(11) = "Landslide"
SearchCols(12) = "Lightning"
SearchCols(13) = "Storm Surge"
SearchCols(14) = "Tsunami"
'continue with all the column names
Dim i As Integer
'Find "Entity" in Row 1
With Sheets("Raw").Rows(1)
For i = LBound(SearchCols) To UBound(SearchCols)
Set t = .Find(SearchCols(i), LookAt:=xlPart)
'If found, copy the column to Sheet 2, Column A
'If not found, present a message
If Not t Is Nothing Then
If Sheets("Result").Range("A1").Value = "" Then
pasteCol = 1
pasteCol = Sheets("Result").Cells(1, .Columns.Count).End(xlToLeft).Offset(0, 1).Column
.Columns(t.Column).EntireColumn.Copy _
Destination:=Sheets("Result").Cells(1, pasteCol)
MsgBox SearchCols(i) & " Not Found"
JD
