Help on Macro for matching data between two sheets
rtyagis
I wanted to put "Matched" in front of a cheque no, if the same cheque number is on another sheet.
e.g. Sheet 1 (tab 1) - we have following data:
Cheque No
12
23
24
25
And on Sheet 2 (tab 2)
Cheque No Matched
22
23 Matched
24 Matched
Please helped me to create a macro for this.
Thanks,
RT
Yo do not need a macro for this pls find the attached.
  • Book1.xlsx
Thanks Nebu for all your help!
This worked perfectly. But the problem is that this activity is going to happen everyday and by a third party, so a macro will be good. Please can you provide me a macro.
Thanks,
RT
There is small change in requirement:
First Match the Cheque No and if the cheque number is matched then copy the Word "Reconciled" column into the sheet 2
Cheque No Reconciled
12
23 Reconciled
24 Reconciled
25
22
23 Reconciled
24 Reconciled
Thanks Again
RT
Hi Nebu,
Thanks, But somehow your macro is not working. Is it possible to add this function on normal MS Excel function like your previous example.
Thanks again,
RT
My apologies I was not very clear on my requirement so posting a sample file and query again -
In Manual Cheque Sheet Check 'Cheque Number' and 'Status'= "Reconciled"
Then go to "Input Manual Cheque", match the cheque no and put Reconciled in front of that, If the status is any other e.g. Unpaid, don't do any thing.
Thanks,
RT
  • Sample-File.xls
Hi:
Please find the attached if you click on Reconcile button it will put the results in column C and the file is saved as a macro enabled workbook in excel 2010.
  • Sample-File.xlsm
@Nebu
Thanks for the Sample File. But currently it's showing every row as reconciled but that is not the case. See the attached file. The "Yellow" coloured were not reconciled and should not be shown as Reconciled.
Thanks,
RT
  • Sample-File.xlsm
Hi Rtyagis,
Please see Attached sheet. I have created two button. click each and see which you have requirement.
Thanks,
Abhishek
  • Sample-File.xlsm
Hi
I have made necessary changes, The code basically copies the status from sheet 1 to sheet2...
  • Sample-File.xlsm
