    Hi Guest,
    Yours,
    Chandoo
  2. Hi All
Help to simple Dashboard
Discussion in 'Excel Dashboards' started by Ida, Apr 20, 2017.
  1. Ida
    Ida New Member
    4
    Hi everyone,
    I am trying to build a dashboard based on the dummy file attached. As I understand, this is most likely done with PowerPivot, but I am not familiar enough with excel to use PowerPivot to that extent. Anyhow, I would basically like to build a tool, which takes a number and add an additional number based on different criteria. The two numbers are on two different sheets, which really troubles me.
    In the dummy-file on 'Sheet 1', I would like separate slicers – or another option with buttons – with “Category” and “Type”, which shows the “Price (number)” for the clicked off item. I would like a third slicer but the data is on 'Sheet 2' where I would like a slicer for “Grown in” and a tap (or two taps – e.g. ‘Florida’ and ‘Local farm’) is clicked on, the “Additional cost (number)” must be added to “Price”.
    The difficulty for me is to how to get 3 slicers in one sheet when the raw data is on teo different sheets along with how to add the two numbers based on the clicks.
    Lastly, I would very much like a relation from the above to “Best before” so when a button is clicked the “Best before” is displayed somewhere on the dashboard.
    I hope this makes sense!
    Best,
    Ida
  2. p45cal
    p45cal Well-Known Member
    694
    Unfortunately for the next few days I don't have acess to a machine with a version of Excel after Excel 2003! So no PowerPivot, no slicers.
    Instead, I've used a short macro to merge the two tables to one on a fresh sheet (Click the button on Sheet 1) as well as adding a New Price column.
    I've run this macro to create the table on the Demo sheet, then added a very basic standard pivot table to the right of the data.
    You should be able to add your own Pivot Slicers easily enough in your version of Excel - I can't here.
    That might get you started towards your own solution.
    NARAYANK991, Ida and Thomas Kuriakose like this.
  3. Ida
    Ida New Member
    4
    Thank you so much p45cal, it worked perfectly. You are a true genius!
Share This Page
