Help with chart
Bshawnr40
I have some data and need to create a chart where the end user can choose the start date to display data for. See the attached example (actual chart is much larger). I have 2 charts created as an example, but want to easily select the start date and only have one chart instead of a chart every day.
Also, Instead of Day 1, Day 2, I would like to show the actual date, starting with the date they choose to display.
Finally - the number of days needed could range from 4 days up to 30 days. Would be nice if that could change also as needed.
  • Sample.xlsx
Nevermind, I figured it out. I did vlookup formulas to pull just the information I needed into a separate table, and built the graph from that. Thanks.
