Help with Counts from a Pivot Table
JuliusV
I have attached mock data of what I am trying to receive the counts for.
Essentially, I have a pivot table with Employee Names and the counts of likes/dislikes. From there, I want to create a table that sums the dislikes based on the Managers of the employee names. I am not allowed to use the source data, but have the relationship between the employee and the manager.
As a note there are three tabs:
Summary Tab - Here is where I am trying to create the manager table
LikeDislike Data - Shows if the employee likes or dislikes
Manager Employee Relationship - Shows who the employees manager is
Thank you for the help!
  • Chandoo Counts Questions_v1.xlsx
Hi Julius,
I think we can get there fairly easy by changing PT layout. First, insert a column between C and D to make some space. Then, on the PT Design Ribbon, Change Report Layout -Tabular, Remove all Subtotals and Grand Total. Filter the Like/Dislike field to only show Dislike. Final result will look like:
Then, your formula in H4 is:
=SUMIF($D$3:$D$14,G4,$C$3:$C$14)
  • Chandoo Counts Questions_LM.xlsx
Hi Luke M,
Thank you very much for your help and for understanding my question!
You definitely made it a lot simpler than all the index match match I was thinking I needed to do.
Thanks,
JuliusV
Hi Julius,
If you use Power Pivot this is easy with that as their is a relationship in two tables. I have Excel 2010 add-in for it, if you are interested I can share the file with you.
Even the pivot tables can be dispensed with , if the data on the Manager Employee Relationship tab repeats the manager's name.
Use the following array formula :
=SUM(COUNTIFS('LikeDislike Data'!$A$2:$A$54,IF('Manager Employee Relationship'!$A$2:$A$17=F4, 'Manager Employee Relationship'!$B$2:$B$17),'LikeDislike Data'!$B$2:$B$54,"Dislike"))
Enter this in G4 and copy down.
Thank you for all the help. I think the pivot table method was the easiest. My original thought process over complicated the problem.
