Help with Index and Match - multiple criteria
I have huge list of items from which I am trying to create a dashboard. I tried to use Index and Match - need help with multiple criteria and multiple range while using Index and Match formula. Any suggestions would be appreciated.
attached are the sample photos. Not sure how to upload the sample file here.
formula used is - =INDEX(INDEX(Backend!$G$2:$T$57,,MATCH(Dashboard!E$4,Backend!$G$1:$T$1,0)),MATCH(Dashboard!$B5,INDEX(Backend!$E$2:$E$57,,MATCH($C$2,Backend!$F$9:$F$57,0)),0))
  • Dashboard.xlsx
Hi Sameer,
Adding another INDEX (in Chihiro's formula) at MATCH lookup_array, will makes it CSE free:
=INDEX(Backend!G$2:G$57,MATCH($B5&$C$2,INDEX(Backend!$E$2:$E$57&Backend!$F$2:$F$57,),0))
One more with SUMIFS:
=SUMIFS(Backend!G$2:G$57,Backend!$E$2:$E$57,$B5,Backend!$F$2:$F$57,$C$2)
Use custom format of:
General;General;"NA"
Display zeros as "NA"
I actually changed it to this way using CSE - =INDEX(INDEX(Backend!$H$2:$V$57,MATCH($B5&$E$1,Backend!$E$2:$E$57&Backend!$F$2:$F$57,0),0),MATCH(Dashboard!E$4,Backend!$H$1:$V$1,0))
