Help with Reset Button
pandoram316
I am trying to create a reset button for a countdown timer.
Can someone help me with a macro for a command button. I am also trying to have the stop timer button time stamp the time that the clock was stopped at on cell J5 (I got that far) and have it continue putting the next new stop time in cell J6 and so on. I just can't figure out how to have it do that.
Here is the macro I have for the starttimer, stoptimer, part.
Thank you
Sub starttimer()
Application.OnTime Now + TimeValue("00:00:01"), "nexttick"
Sub nexttick()
If Sheet1.Range("C1") = 0 Then Exit Sub
Sheet1.Range("C1").Value = Sheet1.Range("C1").Value - TimeValue("00:00:01")
If Sheet1.Range("C1").Value <= TimeValue("00:21:00") Then
Sheet1.Shapes("TextBox 1").Fill.ForeColor.RGB = RGB(255, 0, 0)
Sheet1.Shapes("TextBox 1").Fill.ForeColor.RGB = RGB(0, 255, 0)
starttimer
Sub stoptimer()
x = 1
Application.OnTime Now + TimeValue("00:00:01"), "nexttick", , False
For Each tbox In ActiveSheet.TextBoxes
Range("j" & x).Value = tbox.Text
x = x + 2
Next tbox
