help with resume from pivot table
mario rdz
Dear Ninjas.
I'm doing an extraction from a pivot table, this is for my main graph for a dashboard..
I'm need to get the $ from the last 3 years, for each month and for certain material groups..
The problem comes when I filter a specific group with no spend $$ in a certain year..
The pivot table collapses so in my resume table I loose from wich column I need to get the data..
how can I condition this ??
I appreciate your help
Dear coolsac12
That is exactly what I was looking for,,, thanks a lot...
Just 1 more thing if possible:
What if instead of get the Spend $$ .. I want to get the PO lines ??
The PO line is right beside the $$ for each year-month..
Reagards
Mario
Dear coolsac12
Reagards
Mario
Hi @mario rdz ,
Please use the given formula with Ctrl+Shift+Enter
=IFERROR(INDEX($B$22:$G$33,MATCH($A37,$A$22:$A$33,0),MATCH(B$35&B$36,$B$35:$G$35&$B$21:$G$21,0)),"-")
I have attached the sheet,
  • example(1)(1).xlsx
