How can I delete only cells with a 6 in them
I have 5000 rows on numbers and I want to delete only the ones that have a 6 in them. Is there a command I can use to delete all of them without having to do them 1 at a time. The numbers will be
16,26,36,46,56,66
61,62,63,64,65
Thanks!
Select the Range
Ctrl+F
6
Find All
Ctrl+A
Close
Delete
or
Select the Range
Ctrl+F
6
Find All
Ctrl+A
Delete
Close
Hi Larry ,
Can you try doing a Find and Replace , specifying the search string as :
*6*
I tried find and replace and it would not work because I'm not replacing it with anything and I couldn't figure out how to leave a blank cell The only thing I found that works were to filter the numbers in each column and clear entry
Hi Larry ,
When you do a Find and Replace , if the Replace With input is left blank , then Excel clears all cells of the input string.
Hi:
If Ctrl +H Saves the day I guess you should go for that. If you still want a macro let me know I can write one for you.
The following code borrowed from http://www.thespreadsheetguru.com/the-code-vault/2014/4/21/find-all-instances-with-vba
Does the trick
Sub Find_Clear_Values()
'PURPOSE: Clear all cells containing a specified values
'SOURCE: www.TheSpreadsheetGuru.com
'Modified by Hui to suit this post
Dim fnd As String, FirstFound As String
Dim FoundCell As Range, rng As Range
Dim myRange As Range, LastCell As Range
'What value do you want to find (must be in string form if searching strings)?
'Works ok for numbers as a number
  fnd = 6
Set myRange = ActiveSheet.UsedRange
Set LastCell = myRange.Cells(myRange.Cells.Count)
Set FoundCell = myRange.Find(what:=fnd, after:=LastCell)
'Test to see if anything was found
  If Not FoundCell Is Nothing Then
  FirstFound = FoundCell.Address
  GoTo NothingFound
Set rng = FoundCell
'Loop until cycled through all unique finds
  Do Until FoundCell Is Nothing
  'Find next cell with fnd value
  Set FoundCell = myRange.FindNext(after:=FoundCell)
  'Add found cell to rng range variable
  Set rng = Union(rng, FoundCell)
  'Test to see if cycled through to first found cell
  If FoundCell.Address = FirstFound Then Exit Do
  Loop
'Clear the Found cells
rng.ClearContents
Exit Sub
'Error Handler
NothingFound:
  MsgBox "No values were found in this worksheet"
Mr. Hui what if only want to change the color of the cell instead of delete it?
Such as if I want to change all the cells which have "6" into orange color?
I can not go back with the short cut Control+Z after I use this macro.
Is it possible to make a search bar which searches our requires and shows the cells which have got it in with a different color then let us move back?
Thanks in Advance.
Sincerly..
Simply replace
rng.ClearContents
With
'rng.ClearContents
'Highlight the Found cells
With rng.Interior
  .Pattern = xlSolid
  .Color = 49407
Thank you sir.. It works but I have 2 problems.
First I can not undo it with Control+Z
Second in the attachment file even the values have not got "6" inside H5 and K5 cells show in yellow. These cells have "6" only in the formula not in the results.
(And F5 and J5 aren't be shown in yellow)
  • dada.xlsm
What about Using Conditional Formatting
Select C5:N27
CF
New Rules
Use a Formula
=ABS(RIGHT(C5,1))=6
Apply a format
Apply
This formula gives error.
By the way I wanted to use for a moment, temporary search and see then remove. CF will do it permanently I guess.
Once a macro runs it clears the undo stack and so you cannot after the macro runs
Using CF will also fix the issue with not being to undo changes
If you use the formula
=and($Q$1<>"",ABS(RIGHT(C5,1))=$Q$1)
It will only apply a CF when there is a value in Q1
if Q1 is blank it will not apply any CF
You can use any cell instead of Q1 as well as any value, just change to suit
If you really want a VBA solution here is a much simpler solution
Sub Find_Values2()
Dim C As Range
For Each C In [C5:N27]
  If C.Text Like "*6*" Then C.Interior.Color = 49407
That replaces the entire previous subroutine and does all the cells correctly
Could you please check the following attached file sir?
It finds all 6s if I enter 6 in P1 but it doesn't find 16 if I enter 16.
  • dada2.xlsx
Two issues
1. Change the CF Formula to:
=AND($P$1<>"",ABS(RIGHT(C5,len($p$1)))=$P$1)
2. Never apply CF's to whole columns
You had selected Columns A:N and hence applied 14 x 1000000 CF's
That can Kill spreadsheet performance
Change the section [C5:N27] to what ever range you require
PLEASE NOTE my previous comment
Never (Rarely) Apply any formulas to whole Columns
