How copy data and insert Sheet name together
marreco
Hi, i try copy data in two tabs and tabname to summary sheet.
Sub InsertMySheetNameInColumn()
Dim ws  As Worksheet, LR1 As Long, LR2 As Long, LR3 As Long
    For Each ws In ActiveWorkbook.Worksheets
        If ws.Name <> "Summary" Then
            LR1 = Sheets("Summary").Range("A" & Rows.Count).End(xlUp).Row + 1
            LR2 = ws.Range("A" & Rows.Count).End(xlUp).Row
            LR3 = ws.Range("N" & Rows.Count).End(xlUp).Row
            Worksheets("Summary").Range("E" & LR1).End(xlUp).Offset(1) = ws.Name
            ws.Range("A2:B" & LR2).Copy Destination:=Worksheets("Summary").Range("A" & LR1)
            ws.Range("N2:O" & LR3).Copy Destination:=Worksheets("Summary").Range("N" & LR1)
    Next ws
  • CopyDataAndSheetName.xlsb
Hi, just a logic lack …​
    Dim Ws As Worksheet, LR As Long
For Each Ws In ThisWorkbook.Worksheets
    If Ws.Name <> Plan3.Name Then
             LR = Plan3.Cells(1).CurrentRegion.Rows.Count + 1
        With Ws.Cells(1).CurrentRegion.Rows
            With .Item("2:" & .Count).Columns
                 .Item("A:B").Copy Plan3.Cells(LR, 1)
                 .Item("N:O").Copy Plan3.Cells(LR, 14)
                Plan3.Cells(LR, 5).Resize(.Count - 1).Value = Ws.Name
Next Ws
To understand your issue, initial code updated
with bad or mod codelines in comment :​
'Dim ws  As Worksheet, LR1 As Long, LR2 As Long, LR3 As Long
Dim Ws As Worksheet, LR1 As Long, LR2 As Long
'  For Each Ws In ActiveWorkbook.Worksheets
        If Ws.Name <> "Summary" Then
'          LR1 = Sheets("Summary").Range("A" & Rows.Count).End(xlUp).Row + 1
            LR1 = ThisWorkbook.Worksheets("Summary").Range("A" & Rows.Count).End(xlUp).Row + 1
           LR2 = Ws.Range("A" & Rows.Count).End(xlUp).Row
'          LR3 = Ws.Range("N" & Rows.Count).End(xlUp).Row
'          Worksheets("Summary").Range("E" & LR1).End(xlUp).Offset(1) = Ws.Name
            ThisWorkbook.Worksheets("Summary").Range("E" & LR1).Resize(LR2 - 1).Value = Ws.Name
'          Ws.Range("A2:B" & LR2).Copy Destination:=Worksheets("Summary").Range("A" & LR1)
            Ws.Range("A2:B" & LR2).Copy ThisWorkbook.Worksheets("Summary").Range("A" & LR1)
'          Ws.Range("N2:O" & LR3).Copy Destination:=Worksheets("Summary").Range("N" & LR1)
            Ws.Range("N2:O" & LR2).Copy ThisWorkbook.Worksheets("Summary").Range("N" & LR1)
    Next Ws
You may Like it !
