    Hi Guest,
    Yours,
    Chandoo
  2. Hi All
How to add today data to a summary using button.
Discussion in 'VBA Macros' started by PRAVEENBAGWAN, Jul 13, 2017.
  1. PRAVEENBAGWAN
    PRAVEENBAGWAN New Member
    7
    I have two sheets in attached sample file.
    "today" & "summary"
    I have to send data from "today" worksheet to "summary" worksheet on clicking add button. For example in attached sheet, data from "today" sheet to be entered on clicking add button.
    how to send data from one sheet to empty row of another sheet?
  2. vletm
    vletm Well-Known Member
    2,598
    one possible like this
    Thomas Kuriakose likes this.
  3. SirJB7
    SirJB7 Excel Rōnin
    8,688
    Hi, PRAVEENBAGWAN!
    Welcome to Chandoo forums!
    Checked this yet?
    http://chandoo.org/forum/forums/new-users-please-start-here.14/
    About your question, try this code and assign it to the button action:
    Code (vb):
    Sub A()
        Dim I As Long
        Worksheets("Sheet2").Select
        I = Range("A6").End(xlDown).Row + 1
        With Worksheets("Sheet1").Range("A7:D7")
            ' copy
           .Copy Worksheets("Sheet2").Range("A" & I)
            ' delete
           .ClearContents
    Regards!
  4. PRAVEENBAGWAN
    7
    Thank you so much sir,
  5. SirJB7
    SirJB7 Excel Rōnin
    8,688
    Hi, PRAVEENBAGWAN!
    Glad you solved it. Welcome back whenever needed or wanted.
    Regards!
  6. PRAVEENBAGWAN
    7
    Please share macro for the add button in attached excel sheet to add data range A29:E29 in empty row of "sheet2".
  7. vletm
    2,598
  8. PRAVEENBAGWAN
    7
    Public Sub Copy_Values_Formats_and_Column_Widths()
    Dim destCell As Range
    Set destCell = Worksheets("Sheet2").Cells(Rows.Count, "A").End(xlUp)
    If destCell.Row > 1 Then Set destCell = destCell.Offset(1)
    Worksheets("Bagwan Compu Data Entry").Range("A29:E29").Copy
    destCell.Worksheet.Select
    destCell.Select
    ActiveSheet.Paste
    Selection.PasteSpecial Paste:=xlPasteColumnWidths, Operation:=xlNone, SkipBlanks:=False, Transpose:=False
    Selection.PasteSpecial Paste:=xlPasteValuesAndNumberFormats, Operation:=xlNone, SkipBlanks:=False, Transpose:=False
    destCell.Select
    THIS IS NOT WORKING
  9. PRAVEENBAGWAN
    7
    SAME is not working on the sheet.
  10. vletm
    2,598
    Yes, that would be more than Miracle it #2 would work!
    Your samples have some differences!
    (above 1st sample and below 2nd sample)
  11. PRAVEENBAGWAN
    7
    As per your shared VBA CODE, formulaes are getting copied instead of value.
  12. vletm
    2,598
    Welcome to use VBA.
    There have to be just correct (ALL) settings that it would work as a dream!
    Did You change my code? if not then it cannot work!
Share This Page
