How to create code 128 in Excel
Ken_A
How to create code 128 in Excel, I want to create a special barcode that including my name, my contact number,is it possible?
Hi Ken ,
Have you checked out the following resources on the web ?
1. http://www.youtube.com/watch?v=2ZrTeiMZVxM
2. http://www.ehow.com/how_5008849_make-barcodes-excel.html
Ken_A
Firstly, Welcome to the Chandoo.org forums.
In addition to what Narayank991 suggested please remember that there are a number of various standards for Bar Codes and you need to ensure you use the correct type
There is also a few links where it was discussed here at Chandoo.org forums: http://chandoo.org/forums/topic/draw-barcode-in-excel
The answer is definitely yes.
1. Use the barcode font to create code 128 in excel sheet.
2. Use the office add-in for barcode creation in excel. It is easy to convert the data to barcode.
3. You may just have a try on some online converter :p
Code 128 is capable of encode Upper case letters, lower case letters, numbers and many other characters. So it is possible to encode personal information into it. To get a high quality image, a barcode add-in for Code128 will be a better choice!
Hi Ken ,
Did you check out the links posted earlier ? There are free tools available. Check out this :
http://grandzebu.net/index.php?page=/informatique/codbar-en/code128.htm
Here is a good passage about how to create Code 128 in Excel:
http://www.onbarcode.com/excel_barcode/code_128.html
you can also find many other tutorials, like how to create Code 128 in ASP.NET:
http://www.onbarcode.com/asp_net/code-128-generator.html
Add-in for Excel is the simplest way to generate barcode in E-sheet. Of course, you can integrate barcode font into Excel too.
But I'm not sure I got ur meaning well by downloadable QR code for Excel. You might check the if this QR code Excel library is what you want.
